Reply 17380 of 45944, by kithylin
dexvx wrote:
chose007 wrote:
@dexvx: nice Athlon 1GHz 😁
I got one too, so can finish collecting slot A platform.
Nice, unfortunately, since mine was HP OEM, it only has a somewhat large heatsink. Hard to install a fan because it will get very close to the memory sockets.
I think the classic Athlon (Orion core) 1GHz is much rarer. I was at a recycler and saw an Athlon 700 MHz (Pluto, fastest of that core). May pick it up if it's still there next time.
I've been searching for a 1Ghz Slot-A Athlon Thunderbird (with the full speed cache) for many years now.. I haven't actually seen one actually for sale anywhere since right about when they came out new originally and the 3-5 years after that then they sort of all disappeared. Well rather, I did see one on ebay once for $600.. but that doesn't really count.
Reply 17381 of 45944, by dexvx
It's somewhat rare, but you'd have to expand your search to motherboards and systems as well. I saw another Athlon slot 1GHz (unsure if Classic or TBird) sold for well under $100 in a combo.
Reply 17382 of 45944, by The Serpent Rider
Ladies and gentlemen, I present to you possibly the most powerful AGP 3.3v compatible video card - Galaxy GeForce 7900GS AGP!
939.96 KiB
1.35 MiB
Also Sparkle 6600GT:
1.03 MiB
Reply 17383 of 45944, by Arctic
http://www.cpu-world.com/Cores/Pluto.html
Isn't the Pluto 850MHz the fastest one?
I have a 800MHz Pluto. 😕
Reply 17384 of 45944, by havli
I think he meant the original 250nm K7... which is called Argon I believe and 700 MHz is in fact the fastest model.
Ladies and gentleman, I present to you possibly the most powerful AGP 3.3v compatible video card - Galaxy GeForce 7900GS AGP!
Nice find - but does any of the "bridged" cards actually work in AGP 2x/3.3V? I know NV40 works in i440BX, but no idea on these.
Reply 17385 of 45944, by The Serpent Rider
So far I've tested only GeForce 6600GT and HSI bridge had no problems with 440BX chipset. If I'am no mistaken, someone here mentioned about Galaxy 7600GS working with AGP 3.3v board.
Reply 17386 of 45944, by dexvx
Thanks for correction, I meant Argon @ 700 MHz. Need to head back to the recycler, I recall they have a 486 system. It would be nice since I fried mine 🙁
Reply 17387 of 45944, by oeuvre
An internet friend from another online community sent me this for the price of shipping.
3D Cool tower with AMD Socket A 1GHz, 512MB RAM... complete rig except for HD + sound card. I had an HD + a Yamaha Audician lying around so I tossed them in.
    486.58 KiB
    563.58 KiB
    626.84 KiB
    675.01 KiB
Reply 17388 of 45944, by Carlos S. M.
Nice computer, check the videocard clocks in Everest/AIDA32, it could be ethier an standard TNT2 (125/150 core/mem) or a TNT2 Pro (143/166 core/mem) which is a good videocard for time
Reply 17390 of 45944, by melbar
Nice socket A with the ABIT KT7 😉
Have the same board, but i have to recap it cause several capacitors are worse 😒
Looking at your 2nd picture, there are might be some caps which look not very well...
#1 K6-2/500 [VIA MVP3]
#2 Athlon1200 [VIA KT133]
#3 Celeron1000A [i815EP]
#4 P4-2800 [i845]
Reply 17391 of 45944, by The Serpent Rider
Another rare find - ASUS Deluxe versions of GeForce 4 Ti 4600 and 4200.
1.88 MiB
You don't want to know how cheap they were 😈
Reply 17392 of 45944, by hard1k
Really love the look of that V8460UD. My all times favorite as far as the design is concerned 😀
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 17393 of 45944, by jheronimus
Got my first XT motherboard for free today! It's something called Super 10-B (wasn't able to find any info on it so far) it comes with a Fujitsu MBL-8088-1 CPU and I don't know how much RAM.
2.02 MiB
I have an 8-bit sound card for it (Sound Commander Ex if I remember correctly), an OTIVGA videocard, a serial port card, but not much else. No XT PSU, no XT case, no XT keyboard and, most importantly, no disk controller or any other means of data transfer. So I'm not sure when I'm going to use it (if ever) but still nice to have.
Reply 17395 of 45944, by oeuvre
An NVIDIA MX440 64MB AGP video card and a 1GHz Pentium III Socket 370 for a Dimension 4100 (upgrading from an NVIDIA TNT2 32MB and 733MHz)
Reply 17396 of 45944, by agent_x007
Try itstalling it on Slot 1 440BX board.
457.17 KiB
Reply 17397 of 45944, by carlostex
An AT PSU and AT case can work fine, but you do need a XT keyboard.
OTI VGA cards can be put in CGA compatibility mode, and it works well for the majority of games. For data you can use low Density floppies only, until you are something that allows you to use fixed disks.
Reply 17398 of 45944, by Batyra
Just bought Korg NX5R module with Yamaha DB51 inside 😀
(sellers photo)
    454.67 KiB
    Yamaha DB51XG inside KorgNX5R
    90.89 KiB
    Korg NX5R
Reply 17399 of 45944, by hard1k
Don't forget to reconnect the power cable inside the chassis! They are usually configured for 110V/60Hz
AWE64 Legacy
