Reply 19200 of 52738, by Eleanor1967
debs3759 wrote:
FPUs are automatically enabled. You may have a dead chip (is that on an adapter that plugs between the socket and CPU?). Otherwise, maybe your motherboard BIOS doesn't recognise it, although I think that unlikely.
Yes it is on a adapter which plugs betwenn the CPU and socket. Looks like a sandwich out of pcbs and ics with my pcb mounted 486sx cpu 😁
Well maybe its dead. People here also talk about having on of those adapters and they also do not get detected so I thought maybe there is some reason behind it
Reply 19201 of 52738, by mrau
yes, dead people are easier to detect, dead cpus are harder to detect ;p
you did check bios?
Reply 19202 of 52738, by dexvx
Got a Voodoo 3 2000 AGP with box, insert, and CD. Box condition is great.
Got this Gigabyte GA-5AX with unknown CPU in dusty condition. For some reason there was an Aopen AX53 manual along with it. Cleaned it up and found it was a K6/2 300, so nothing really special.
Before
After
Reply 19203 of 52738, by cyclone3d
My Aztech Sound Galaxy collection is growing.. at least the cards I am interested in for now.
Just picked up a Sound Galaxy BX II. Pretty rare to see them for sale. I was looking at pictures and from what I can find, there were at least 3 revisions of the card. The earlier one using the standard OPL2 chip and the newer ones using the low power OPL2 chip.
It is basically a Sound Blaster 2.0 card.
Seller's pic:
324.26 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 19204 of 52738, by tikoellner
cyclone3d wrote:
My Aztech Sound Galaxy collection is growing.. at least the cards I am interested in for now. […]
Seller's pic:
Nice. I really much like those older Aztech sound cards. I also have some branded as "CPS Hamburg" (Aztech Sound Galaxy NX II). While some of them are Sound Blaster clones and they are generally not considered "iconic" as early cards from SB line, their output quality seems actually better, much less noisy.
Reply 19205 of 52738, by Nvm1
debs3759 wrote:
Eleanor1967 wrote:
I recently bought a Cyrix Cx487S-40QP. Installed it in the motherboard along with an 486SX but the motherboard still shows no co-processor installed. Anybody got an idea if you have to enable it somehow or how to get this thing to work ?
As far as I know those only work with the Cyrix Cx486S fastmath cpu's. I have on of those combinations and it never worked with another 486.
Reply 19206 of 52738, by Stermy57
probnot wrote:
*scrolls through pictures* […]
Almoststew1990 wrote:
Today I wasted £20! I saw an advert for a Tiny - branded PC P3 Slot 1 PC which always gets me interested (although without PSU or a side panel) and when I picked it up it and got it home it looked like this:\
That should clean up fine, I've seen ones this dirty...
https://i.imgur.com/i1j0JKwl.jpg […]
Oh...nevermind...Yeaaah, that's a double whammy there.
Chsi Caps... Really bad caps!
This is my story:
Some weeks ago i bought an MSI K7 Pro@MS-6195, it was new, never opened!
I was excited because it was my first Slot A Mainboard for only 15€ shipped.
The box was in very good condition, wonderful bundle, never used... All was like expected from a new mainboard but the board had bulged caps!
My face was something like this 😮
So this Mainboard was stored for 17 years into the original box but its horrible caps go to crap's cemetery without a single bootup 😜
Never seen something like this 😁 fortunately i have good soldering skills so it wasn't a big problem 😀
In my experience old MSI and Gigabyte Mainboards but even some ABIT and Epox use bad caps like Choyo, Chsi, G-Luxon, Hemei, Su'Scon etc in my opinion is better to know before buying
Reply 19207 of 52738, by bjwil1991
Seller's pic:
Nice sound card. I have a Sound Galaxy NX Pro that is SB Pro, Covox Sound Things, Disney Sound Source, and has a genuine OPL3 YMF262-M chip. The Line-In port needs to get re-soldered since it stops working when I wiggle the cable and it's loose. Other than that, the card does work surprisingly very well.
Reply 19208 of 52738, by appiah4
Stermy57 wrote:
Chsi Caps... Really bad caps! This is my story: Some weeks ago i bought an MSI K7 Pro@MS-6195, it was new, never opened! I was […]
This is my story:
Correct me if wromg but actually not being used at all is worse for the caps than some use?
Reply 19209 of 52738, by gdjacobs
Energized with only leakage current is best. However, Chhsi along with Fuhjyyu are true D-list crap. Real caps won't fail in the box.
Reply 19210 of 52738, by anachronism1887
A Comtex TurboXT off of Craigslist recently.
3.23 MiB
121.68 KiB
Besides being dusty, the system powered on just fine. Installed was MS-DOS 3.3, a Siemens 8088 CPU, no 8087 co-processor, standard amounts of RAM but there are open sockets that I could populate if I wanted to. Installed cards were a GW202 Baby I/O controller that only supports low density disks, a MDA adapter, and a hard disk controller. Other hardware was a Seagate ST-225 that seems to work just fine and a 360KB floppy drive that died out almost immediately. I've added TEAC 360KB and 720KB drives and a Microsoft InPort Bus Mouse controller if I ever want to use a mouse. I am probably going to swap the current I/O controller with something that can handle high density disks but I haven't decided that yet.
Unfortunately, the Hyundai monitor has some pretty bad burn in but I can live with it.
67.92 KiB
The keyboard has white Alps switches and still needs a more thorough cleaning since there were tabs of tape on the keys with Chinese characters on it. The adhesive was really broken down and some ink has transferred to the key caps.
82.42 KiB
85.22 KiB
I also had to re-pin the reset and turbo buttons since they would not make proper contact with the motherboard headers and would just wobble around. Next I will need to clean out the drive but there really isn't much on it beside WordPerfect 5, an old version of The Print Shop and a Chinese Word Processor. I don't see any personal data so at least the previous owner scrubbed that.
Reply 19211 of 52738, by lazibayer
Bought 4 RAMBUS sticks and they arrived exactly as pictured below:
64.29 KiB
Just four bare sticks and two deflated airbags in a box. I will test them tonight.
Reply 19212 of 52738, by Batyra
Nice! I havent seen this revision yet.
Reply 19213 of 52738, by brostenen
psychz wrote:
Looks like it was a console week over here 😮 After a second Dreamcast, I got my first PlayStation... Only 23 years late to the party 😢 For 9€, a SCPH-1002 (first PAL release/the "audiophile edition"), two basic controllers (SCPH-1080, no dualshocks 🙁 ), its AC cord, its original A/V cable and a boxed 3rd party PSX<->SCART cable. Fully working, fully silent. Guess it's time to pack away the PS2 and play those old games (*coughcough*Ridge Racer*coughcough*) on the console they were made for. Oh, it is already chipped too!
Had that model as well, back when they were new. Never liked ridge racer my self. I was more a rage racer kind of person. Now with that chip, you need to check out other games. If you do not know it, then try Dead Or Alive 1 that were released for Ps1. Wipeout is great too.
Reply 19214 of 52738, by appiah4
Grabbed a QDI Socket 7 board and a Pentium 100 CPU because it was a cheap bundle:
Also grabbed two SB AWE64 CT4520s (even though I needed only the one.. you can never have too many AWE64s..)
And finally, the seller threw this into the lot as a bonus:
Reply 19215 of 52738, by Groovy
Since I am the only one at work using retro PC's I end up with all the incoming old hardware. Today I was told by my employer that he had two boxes for me to take home after work, I was told there were 2 old CRT monitors and an old PC. This is what I ended up with. I really like my job some days.
Silicon Graphics Indigo 2
NEC MultiSync E1100 21" Monitor
New in the box IBM 3151 Serial Terminal still in shrink wrap from IBM
Reply 19216 of 52738, by debs3759
appiah4 wrote:
Grabbed a QDI Socket 7 board and a Pentium 100 CPU because it was a cheap bundle: […]
Shame it's missing the original heatsink and fan, they are half the value.
Reply 19217 of 52738, by probnot
Picked up 2 sound cards. The Sound Blaster Pro 2.0 is for my 286 upgrade. The Sound Blaster 16 is because it's good to have a backup.
3.39 MiB
3.52 MiB
Reply 19219 of 52738, by cj_reha
Got one of these Nakamichi 5 CD changer drives. I think it was around $30 shipped.
Demo of it loading and storing 5 CDs and ejecting them with cover off: https://www.youtube.com/watch?v=iodxMJQVmnc
