Reply 28200 of 53139, by wiretap
- Oldbie
Well, my IWILL ZMAXdp just blew a capacitor in the power supply.. ugh, capacitor plague era PSU. Everything looked good on it too -- since I looked inside with a flashlight when it arrived. The pop scared the shit out of me.. almost sounded like a .22 gunshot and the computer just turned off. Time for a recap, and hopefully nothing else got damaged. I was almost through the Windows XP install! haha
Correction.. just tore apart the power supply. One buldging cap on the DC side, but what blew was the fuse in the power supply. It left a little scorch mark on the PSU's board. Both look like easy repairs.. but there may have been another short that caused it to fail. Fuse is rated at 250V/2.5A, the peak load that the power supply claims is 350w, with 300w continuous. Power supply is a Channel Well (CWT) T43B014. So, not the best quality power supply, but it is proprietary.. I think. It is like ATX size in the height and width, but half length with the power routed out the bottom, and two 80mm fans to draw air through the CPU heatsinks and exhaust it through the power supply. Anyone know of any equivalent power supplies? Probably not, 🤣. I'd like to upgrade it to the 400/450w that the IWILL ZMAXd2 came with. Needs 24-pin + 8-pin EPS.
Edit2 for pics:
CONQUER FUSE MET F2.5 250V
One slightly bulging cap..
