Reply 34180 of 57144, by boxpressed
This card arrived today. It's a Tseng ET4000AX VLB. I believe that the ET4000AX chip was manufactured in the 12th week of 1992.
I'm not sure of the OEM, but it is apparently an "Eng. Sample." NSSI recognizes it as a 1MB Tseng card. It works perfectly, and the colors really pop.
The attachment IMG_9534.jpg is no longer available
Reply 34181 of 57144, by daikatana_
I just received this. It's in a sorry state. But it was almost free, so I took it. I don't even know if it works.
Game MIDI soundtracks
Retro games and HW reviews
Reply 34182 of 57144, by luckybob
Honestly those are the best aquisitions, imho. And if it doesn't work, making it work is SO satisifying.
Reply 34183 of 57144, by mpe
boxpressed wrote on 2020-05-26, 20:16:
That's cool. Looks like a very early VLB device. I have ET4000AX of about the same age. But that's a pre-VESA local bus implementation.
Blog|NexGen 586|S4
Reply 34184 of 57144, by daikatana_
luckybob wrote on 2020-05-26, 21:12:
That's so true. I'll test the module tomorrow.
Reply 34185 of 57144, by boxpressed
mpe wrote on 2020-05-26, 21:16:
I have what I believe to be the production version of this card on the way. It even comes with a manual and drivers, so I should know more about its branding soon. I think it is a "generic" OEM and not one of the big-name companies.
Yes, the ET4000AX shows its ISA lineage in my benchmarking. It's about 10% slower in Superscape and Doom than my other VLB cards (Cirrus, NCR, ET4000/w32p).
Reply 34187 of 57144, by creepingnet
Well, I won this strangely, and possibly Tandy 1000 compatible LightPen on E-bay today. No real basis except that it uses a DB-9 female port and I have enough electronics skills to backup actually figuring out the pinout and looking at the circuit. I'm kind of hoping it's one of the "Warp Speed" light pens - the connector looks right and it looks like some documentation pictures - and I have the software from some experiments. Will check the pinout first - since I have the Tandy's pinout for the lightpen port written down in my desk from my experiments last summer (where I almost make a working one but was having trouble with tracking being very consistent or working at all).
The attachment lightpen.jpg is no longer available
~The Creeping Network~
Reply 34188 of 57144, by Bancho
Saw this ARK2000 Card for a very cheap price so decided to grab it.
Reply 34189 of 57144, by newtmonkey
This came in the mail today:
Sound Blaster 16 CT1740
It was listed as untested/not working and I got it for a steal. Sadly, it's got one of the "hanging note bug" DSPs.
Even more sadly, it doesn't seem to output anything on the left channel. It might just be a matter of applying some contact cleaner to the speaker OUT jack, but since it's got the hanging note bug and since I use external MT-32/MIDI I'm not really inclined to replace my AWE64 just to get better FM music. I'll store it away for now and revisit it at a later date, once I eventually get a dedicated MPU card clone, etc.
Reply 34190 of 57144, by Predator99
Predator99 wrote on 2020-05-23, 13:09:
I decided to collect the missing Chips for my junk AMIGA A2620 card Bought these (retro) hardware today […]
I got all 3 from different sources and at the end I paid a lot of money for them (incl. shipping..):
68882 22,50€
68851 30€
68020 11,5€
Hope I get it working, did not test anything so far...
Today I took the time to make a short test of my 68020 Turbo-Card:
Sellers Picture:
The attachment eb.jpg is no longer available
Added some gold:
The attachment IMG_9130r.jpg is no longer available
In my A2000:
The attachment IMG_7090r.jpg is no longer available
The attachment IMG_7089r.jpg is no longer available
But I have to admit I had to close J303 to disable Fast-Ram...without that an error appears.
Reply 34191 of 57144, by lolo799
MAZter wrote on 2020-05-26, 23:52:
yes https://i.postimg.cc/cLLGsCsr/IMG-20200526-173511.jpg […]
lolo799 wrote on 2020-05-26, 17:57:
Could you take a picture of the ram expansion port?
yes
Same on my models, except I have the 4M ram expansion in each, and somehow I have one half of the 16M expansion.
Reply 34192 of 57144, by CrFr
Got this macintosh Color Classic today. Seller said the condition is unknown. Usually when I see that said, I assume the seller knows it's broken. So I sent him a real low offer, and to my surprise he accepted. This time it was nice exception, it booted right up.
Seems quite dirty, but everything is intact. No cracked plastics or anything, no big scratches, no burn in. It isn't even yellowed. Some sticker glue residue in couple of places. I think after good cleaning this will look really nice. Now only if I had mouse and keyboard for this 😒
The attachment IMG_0900_DxO.jpg is no longer available
I like this plug and play motherboard, slides right out of the case.
The attachment IMG_0901_DxO.jpg is no longer available
Screen has slightly darker area in the upper right corner. Other than that, it is really sharp and good looking. Seeing that it has finnish language operating system is nice.
The attachment IMG_0906_DxO.jpg is no longer available
Reply 34193 of 57144, by darry
CrFr wrote on 2020-05-27, 20:04:
Got this macintosh Color Classic today. Seller said the condition is unknown. Usually when I see that said, I assume the seller […]
ADB mice and keyboards are expensive . There is also this https://www.bigmessowires.com/usb-wombat/ , if you want to use USb peripherals instead . Less authentic, more practical , IMHO .
Reply 34194 of 57144, by Vynix
That CRT might need to be degaussed, also, I'd recap the whole machine if I were you, some compact Macs were known for suffering from leaky SMD capacitors.
On top of my head I know that the following compact units are affected (I'm excluding the other Macs) :
  • Macintosh SE/30 (the SE seems to be unaffected)
  • Macintosh Classic
  • Macintosh Classic II
  • Macintosh Color Classic (not sure about the "obscure" Color Classic II)
The older (128K, 512K, 512Ke, Plus, Plus/ED, OG SE and SE FDHD) could benefit from a analog board recap and the replacement of the axial caps that they use (which didn't go bad as much as the SMD shitcans used on later 68K units).
Also careful about that PRAM battery, these are known for exploding and often taking the logic board with them.
Reply 34195 of 57144, by Caluser2000
Got this stash delivered today.
Reply 34196 of 57144, by chrismeyer6
Great haul Caluser
Reply 34197 of 57144, by Intel486dx33
This website has some good resources and you can access it from your color classic with Netscape 3.1 web browser.
http://obsolete.macfixer.com/vintage-software/
You can download to a mac computer and then burn to a CD.
But you will need a CDROM drive for your Macintosh.
I would upgrade your Color classic with a 500gb hard-drive at least first. And add more RAM. I think it take up to 16mb.
( Apple Quantum Fireball SCSI 500mb hard drive )
All you need is 8mb to use Netscape and go online.
Also get a network card. They are cheap.
System 7.1 is light on the CPU. ( if you only have 8mb ram ) ( I think you have to install from floppy disks ).
System 7.5 used al little more resources. ( if you have 16mb ram )
Don’t put anything higher than System 7.5.1
Also get an Apple SCSI CDROM drive. You can build your own SCSI CDROM drive using the Apple CD300i or CD600i drive.
Replace the battery.
OWC computers NO longer supports this computer as it is too old. But you can find parts on eBay.
Specs
https://everymac.com/systems/apple/mac_classi … lorclassic.html
See my Posts:
Macintosh Color Classic ( Extreme )
Reply 34198 of 57144, by MAZter
lolo799 wrote on 2020-05-27, 19:04:
Nice, what are these memory modules called? Are they have part numbers?
Reply 34199 of 57144, by Caluser2000
chrismeyer6 wrote on 2020-05-28, 00:29:
Great haul Caluser
Thanks. The plastic covered one had a 3.4Ghz P4 and the Grey one a 2.8Ghz Celeron. Swapped out the Celeron mobo with the P4 one which more ram slots and was fitted with 2gig of DDR400 ram. The 40gig hdd in the grey box has a fresh install of XP on it which asks for activation. I'll fit a far larger drive and install some flavour of Linux on it. Paid $nz60. That included petrol money for the seller to drive 50km to drop it off this morning. I was really only interested in the monitor but the seller put in some other goodies as well which I thought was nice of him.😀 Threw the plastic covered case in the recycling after stripping all the components I could use on other system/projects. It came with a combo 3.5" fdd/CF/SD card unit and DCD rw drive.
