Reply 35900 of 36691, by Predator99
Yes, maybe I will tell him how much value he destroyed...after receiving the 2nd box. he didnt answer on my question if he has other parts left. In another auction he sold the remains of the PSUs...
Top right is this one:
https://bigbookofamigahardware.com/bboah/prod … ct.aspx?id=1792
The Hypercom 3 connects to the clock port of the A1200 and provides it with a high speed serial port (460,000bps) and a high speed bi-directional parallel port (560,000bps). The Port Plus is simply believe to be a Hypercom 3, rebadged and sold by Eyetech
Reply 35901 of 36691, by cyclone3d
Personally I wouldn't really mention it to the seller lest you destroy your chances of buying similar "scrap" lots in the future.
Last time I tried to tell a seller about how they destroyed a good card by cutting off the edge connector they told me they received it that way... yeah, right....
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 35902 of 36691, by Predator99
The other small card belongs to this (Ebay picture):
MICRONIK Z-1i BUSBOARD 6860 Rev.5.44 ZorroII-ISA-PCI for Amiga 1200 A1200 tower
The busboard itself will come with the 2nd box hopefully...
71.7 KiB
Reply 35903 of 36691, by Predator99
cyclone3d wrote on 2020-09-10, 21:20:
I would be more happy if the systems would still be in one piece than buying cheap scrap lots...so maybe next time he will offer the whole PC. I wouldnt buy it for 2000€, but others for sure...
Reply 35907 of 36691, by Stiletto
dionb wrote on 2020-09-10, 08:22:
Whoa, that's a monster. […]
kolderman wrote on 2020-09-10, 08:03:
No, I was talking much simpler design:
Ic0A7pwNKZWtfOiuRcVn9Ya_5pLzuA2de3tFwQCwt_MfuC1oz78D8-DcEucUvcqAMVc4M9zyVBvI7swyLHdGgArFwndCLnnrglMlKNI
BTW, you messed up your photo embed from Google.
If it's hosted on Google Photos, try this: Re: Televideo Telewave Audio 32 sound card, questions about its onboard wavetable ROM
If it's on Google Drive, there's something else to do instead.
OR you could always attach the photo.
do the Fandango!" - Queen
Stiletto
Reply 35908 of 36691, by NyLan
Bought an usb floppy drive because I didn't have one...
1.14 MiB
.. and 35x disks because I didn't have enough 😏😁
1.63 MiB
20€ total, that 's ok here.
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Reply 35909 of 36691, by gdjacobs
appiah4 wrote on 2020-09-08, 11:26:
Teapos from 14-15 year ago are the epitome of capacitor plague in my experience, all my Socket A stuff with Teapo caps bulged and leaked.
Teapo low/ultra low ESR caps are crap. More general purpose Teapo caps are better.
Reply 35910 of 36691, by Repo Man11
cyclone3d wrote on 2020-09-10, 03:40:
The smaller one has thin fins so it wouldn't surprise me if it cools better. The big one has a thicker base so it will probably take longer to heat up and the temps will probably stay more steady but the CPU will probably run hotter overall.
Prepare to be surprised. I did a test, and the outcome was no surprise to me. I ran Prime95 for over an hour with both coolers installed, all else the same, using Arctic Silver 5 on both. The AX7 was 10 degrees cooler, while still being less noisy.
AX7:
Adaptec:
Reply 35911 of 36691, by cyclone3d
Repo Man11 wrote on 2020-09-11, 02:14:
Prepare to be surprised. I did a test, and the outcome was no surprise to me. I ran Prime95 for over an hour with both coolers i […]
AX7:
Adaptec:
Very cool 😁. Not what I was expecting.
Yamaha YMF7x4 Guide
Reply 35912 of 36691, by kolderman
U got programming mags from early 90s? I got programming mags from early 90s.
Reply 35913 of 36691, by Predator99
Predator99 wrote on 2020-09-08, 19:12:
Saved in cooperation with imi (THANKS again!). Who spots the most valuable item? Sellers pics. s-l1600 (3).jpg s-l1600 (1).jpg […]
Sellers pics.
box 1 continued...
1.4 MiB
700.58 KiB
525.85 KiB
1.08 MiB
Reply 35914 of 36691, by Predator99
998.63 KiB
876.97 KiB
Somebody spots something else interesting on the overview photo? Think the remaining parts are standard/trash...
444.56 KiB
Reply 35916 of 36691, by devius
Predator99 wrote on 2020-09-11, 07:57:
box 1 continued... IMG_1015r.jpg IMG_1019r.jpg IMG_1023r.jpg IMG_1025r.jpg […]
box 1 continued...
Mind adding some description for those of us not versed in MCA? I mean, one of them says "Ram Expansion", so no questions there, but the others I have no idea what they are.
Reply 35917 of 36691, by Predator99
devius wrote on 2020-09-11, 08:51:
box 1 continued...
Also no expert and have to google. But the most important everybody should know is the original IBM 8514/A 😉
https://en.wikipedia.org/wiki/IBM_8514
Reply 35918 of 36691, by luckybob
#1 IBM 8514/A One of the very first VGA cards with some form of 2D acceleration
#2 probably a parallel port card - i'd have to google the 40-pin dip chips to be sure
#3 2-8mb expansion board. Probably designed for the 386 IBM model 80, but would fit most ps/2 systems with a 32-bit MCA slot.
Also, those 72-pin simms that were in that same lot of items, go in that board. Its special ram.
Reply 35919 of 36691, by appiah4
Predator99 wrote on 2020-09-11, 07:58:
IMG_1026r.jpg IMG_1028r.jpg […]
There is an Amiga accelerator in there, looks like an 020 or 030 for an A1200?
The rest is certainly not standard/trash either IMO..
