Reply 36080 of 36638, by imi
Hezus wrote on 2020-09-20, 17:34:
Second one is a NEC XR385, which is a Yahama DB60XG clone. 4 mb of gorgeous MIDI soundfonts! Going to have some fun trying this in several games that support it.
awesome ^^
definitely a good box
Reply 36082 of 36638, by SpectriaForce
Moarr S462 goodness
NOS PC CHIPS M811
277.58 KiB
334.16 KiB
(that disclaimer at the bottom 🤣)
NOS MSI KT4 Ultra
222.13 KiB
256.75 KiB
NOS Asus A7N266-C
306.7 KiB
All these S462 will be recapped as far as needed (already made a inventory).
I sell 'ridiculously expensive' retro hardware to people like you. I feel sorry for that.
Reply 36083 of 36638, by SpectriaForce
NOS Asus MEW (socket 370 PPGA only + PCI only)
251.09 KiB
Quality board from 1999 with Japanese capacitors.
I'm not sure yet whether I'm going to pair this with a PCI FX5500, MX4000 or even a Voodoo2.
NOS PATA HDD and CPU
222.46 KiB
Reply 36085 of 36638, by Horun
Nice mobo's ! All I found this weekend was some 1.44Mb floppy disks. Box of 50 for $6.50 (was half off yellow tag price). Odd thing is the side label says 1995 and 7/95-S/H, wonder if they are that old or TDK just kept using same box style for a long time....
Anyway, you can not have too much media for vintage gear 😀
    80.23 KiB
    185.88 KiB
Reply 36086 of 36638, by darry
As mentioned in another thread, I ordered a NOS OEM AWE64 Value (CT4520) to test whether the craptastic line-out noise performance on mine is typical or if I have an outlier .
My CT4520 unit has low volume pulsing noise (probably below -60dB, I did not measure) on line-out which my CT4520 CT4500 does not .
EDIT: Edited for clarity and to correct typos . My original post made no sense .
Reply 36087 of 36638, by Horun
darry wrote on 2020-09-21, 00:26:
My unit has low volume pulsing noise (probably below -60dB, I did not measure) on line-out which my CT4520 does not .
Which card is "My unit" ? Hope new one works ok. Have read there are some variants of the ct4520, some were worse than the earlier 4380 that it replaced.
Reply 36088 of 36638, by EvieSigma
Horun wrote on 2020-09-20, 00:56:
EvieSigma wrote on 2020-09-20, 00:28:
You certainly don't find 2400bps Hayes modems at Goodwill very often. Of course the annoying 9VAC power supply is missing, thoug […]
You certainly don't find 2400bps Hayes modems at Goodwill very often. Of course the annoying 9VAC power supply is missing, though.
EiS5EI0XkAQnXAL?format=jpg&name=large
Nice ! Yes Goodwill is bad at not keeping the AC adapter with the unit intended (so they can get a few extra $ selling it separate). Did you look over the shelves to see if it was in with cables and stuff ?
I keep my eye out for any external serial modem, have yet to find a decent 2400 but have found a few 28.8 and 33.6
I actually found this in the "Outlet Center" part of the store (along with a pair of Creative branded PC speakers I also grabbed) and while I found what might have been a 25-pin serial cable to go with it (that I didn't buy because I didn't know if it was serial or parallel) I could not find a power supply even after an extensive search.
Reply 36089 of 36638, by pete8475
Horun wrote on 2020-09-20, 23:25:
I remember buying TDK disks in that exact style of box in late 96.
Reply 36090 of 36638, by darry
Horun wrote on 2020-09-21, 01:56:
Sorry about that.
I just re-read and corrected my post .
Basically, the CT4520 line-out is crappy. The Ct4500 line-out is much better . The CT4500 has crappy line-in . The CT4520 line-in is better .
I also ran some line-in tests on another CT4520 that I have in another machine . See Noisy AWE64 recording from any input (line in, EMU8000 MIDI, etc) + upcoming AWE64 comparison
Reply 36091 of 36638, by feipoa
mpe wrote on 2020-09-19, 11:33:
Also arrived today. Micronics-branded dual socket 5 / 430NX. IBM part made by Micronics in full-AT form factor. […]
I notice the board has two Intel Overdrives. Didn't Intel disable SMP in their overdrives? Or was that just the MMX overdrives?
Reply 36092 of 36638, by mpe
feipoa wrote on 2020-09-21, 07:12:
This is what I am trying to find out 😀 It came with two P90's which is what it was designed for. Those I installed are Socket 5 overdrives which should be close to stock CPUs.
MMX Overdrives don't support SMP. Non-MMX might as there are hints in datasheets saying so.
Blog||486DX-50|NexGen 586|S4
Reply 36093 of 36638, by bearking
I've got this nice kit today for a good price(23 euro incl. shipping)
1.4 MiB
Soyo 019R1 mobo with 128 kb cache + Cyrix Cx486DLC-40GP + Cyrix Cx87DLC-40QP + 4 Mb SIMM 30 RAM.
And also this 8-bit multi-i/o card
750.96 KiB
Unfortunately, the board is playing dead with me; all the chips are getting warm but still no beep, no video and also nothing on the POST card... only the LED-s are light up.
PS: I've already removed the varta...
Reply 36094 of 36638, by Montaron
Couldn't wait for Jensen to hurry up baking the next batch of 3000 series cards..
4000 series courtesy of PNY
678.38 KiB
Ye already be disturbed; now leave me be. Yer company be toil enough as is.
Reply 36095 of 36638, by Horun
Back to the GW to check for more media and got 150 DVD blanks for $10. They have a shelf full of unopened various brands DVD+R and some DVD-R for $3 or $4 for 50 packs or $7 or $9 for 100 packs.
The little 25 packs were also $3.... Any body need some DVD media for cheap ? These are what I left on the shelf......
    146.13 KiB
Reply 36096 of 36638, by feipoa
mpe wrote on 2020-09-21, 07:20:
This is what I am trying to find out :) It came with two P90's which is what it was designed for. Those I installed are Socket 5 overdrives which should be close to stock CPUs.
It's a real shame about Intel removing SMP for the MMX overdrives. Please keep me informed about the non-MMX overdrives.
Reply 36097 of 36638, by Artex
bearking wrote on 2020-09-21, 22:25:
Looks great! I love that gold Cyrix printing on the chip. +15 ns cache +Cyrix FPU +Barrel removal and you're already golden. Make a new thread!
Click [here] to see my collection of retro bliss!
Click [here] to see my "I just gotta have it"' list!
Reply 36098 of 36638, by Horun
Artex wrote on 2020-09-22, 00:55:
Sweet ! That is a great bargain for everything.
Reply 36099 of 36638, by happycube
Horun wrote on 2020-09-21, 23:37:
I don't need them, but the Fuji +R's might (or might not) be Taiyo Yuden.
