Reply 36920 of 37740, by HanJammer
Not really anything special and condition of some cards is so-so but will come in handy for building some rigs for sale... I'm mostly interested in the MiroMedia Surround card - addon DSP for regular sound cards. It implements Dolby Surround for 2 or 2+1 speaker setup so I hope for it being a bit more than just another 'spatializer' which was a common thing on sound cards back then... Also the Digitan DSAC-300 sound card seems a bit uncommon. Havn't seen one before...
Check out my AmiBay and eBay for ISA and PCI card, 286/386/486 Pentium motherboards and more.
Reply 36921 of 37740, by Xicor
Salient wrote on 2020-11-16, 19:53:
Xicor wrote on 2020-11-16, 17:47:
.... Today i received a new member for my midi "tower of power", a Korg NX5R (@110€ including shipping), that has seen a lot of […]
Today i received a new member for my midi "tower of power", a Korg NX5R (@110€ including shipping), that has seen a lot of action in the "battlefield", but nevertheless fully functional.
I was fearing that past owner had scavenged the Yamaha module, it turned out to be where it should.
That is a great price! I paid about that amount for just the DB51XG board.
Thanks to your work @ www.wavetable.nl, we all can choose the modules and sound cards that for each of us are more appealing , and to me it was an invaluable help to make my mind on which ones to pick... So, my hat's off to you Sir !!
Also, I feel sorry for the NX5R that roams the earth without its companion DB51XG....
Reply 36922 of 37740, by BetaC
Today I spent an extreme amount on some hardware.
1.5 MiB
An entire $5 for a bootable 133 PATA drive and SATA drive combo. Now I only need to figure out how to get it to boot off of PATA when something SATA is also attached.
Reply 36923 of 37740, by Warlord
I got this kinda cool card, I put it in my 486 and it instantly worked. It is like XTIDE except it's OG XTIDE from the 90s before XTIDE existed. Also it fixed y2k bug. It detected my 32gb CF and let me format 32gb. no compatibility issues with my VLB Adaptec IDE controller. It also cost me way less than XTIDE cards you fine on ebay.
    178.39 KiB
    234.98 KiB
Reply 36924 of 37740, by debs3759
Warlord wrote on 2020-11-19, 02:01:
Any price is better than this one
Reply 36926 of 37740, by hyoenmadan
Would be good to have backup's of these card ROMs. As far as I have seen, some of these INT13 ROMs have better compatibility with old gear and mixtures between integrated IDE controllers and HBAs than XTIDE.
Reply 36927 of 37740, by Warlord
I have to look into how to dump the rom. Physically the pcb layout is not that complex. Not sure tho that the rom will work in a network card like XTIDE. I have the manual aswell. It probably wouldn't be that hard to clone the card.
Reply 36928 of 37740, by yawetaG
BetaC wrote on 2020-11-19, 01:38:
Well, as long as it doesn't use the same stupid SATA/PATA implementation as some early SATA Dells (the SATA bus on those is actually connected directly to the PATA bus via an integrated adapter, so you can use either SATA or PATA but not both...)
Reply 36929 of 37740, by BetaC
yawetaG wrote on 2020-11-19, 08:47:
They both work simultaneously, the only real issue is the one I mentioned, and it not supporting ATAPI, which means I will eventually need to re-burn a bunch of disks to make my CD drives happy again instead of just cheating with a more modern SATA drive.
Reply 36930 of 37740, by HanJammer
That's cool! Please dump the EPROM if you can.
Reply 36931 of 37740, by wiretap
Found an Ebay seller (radimf78) with a bunch of these for sale, so I picked one up.. yay, no more using shoddy pry tools to remove PGA CPU's. 😁
Circuit Board Repair Manuals
Turbo Display Project
Dual Socket 8 Project
Reply 36933 of 37740, by debs3759
chrismeyer6 wrote on 2020-11-19, 16:06:
Nice find. That tool looks like a fin comb for straightening fins on AC/refrigeration equipment.
It is a PGA CPU removal tool for motherboards without ZIF socket. Most that I have seen came in upgrade kits.
Reply 36934 of 37740, by gex85
I was casually browsing the local classifieds site today when I came across an ad with a title similar to "PC and a lot of various PC and laptop parts". The whole pile for 10€, but located a two hours drive south from my place. Looked into it, saw the first picture, immediately asked the seller whether he would agree to ship a single item, which he did. Here it is:
1.11 MiB
sellers photo
So yeah, that's an ASUS P5A right there, including some unknown CPU, for 15€ shipped.
Let's hope it still works. I haven't looked into the various revisions of the P5A yet, it seems that some are more desirable than others, so fingers crossed this was a good buy.
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 36935 of 37740, by cyclone3d
gex85 wrote on 2020-11-19, 16:32:
I was casually browsing the local classifieds site today when I came across an ad with a title similar to "PC and a lot of vario […]
Nice. As it has the tag chip, it is an earlier version that shouldn't need modding to support the K6-2+ / K6-3+ CPUs properly.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 36936 of 37740, by kolderman
cyclone3d wrote on 2020-11-19, 18:24:
Which one is that exactly? And the later versions are still quite good combined with a MMX that can also be slowed down with setmul (not multiplier though).
Reply 36937 of 37740, by cyclone3d
The tag chip is the smaller chip next to the northbridge.
The 1.05 and 1.06 are the ones that have to be modded to work properly with the K6-2+ and K6-3+
K6-2/3+ Success on Asus P5A 1.06 - simple mod
Yamaha YMF7x4 Guide
Reply 36938 of 37740, by gex85
Nice, thanks for pointing that out. I still have a few K6-2+ 550 MHz CPUs sitting in the drawer (all of them overclock to 600 MHz without issues), so that should be a nice fit!
Reply 36939 of 37740, by GL1zdA
HanJammer wrote on 2020-11-18, 09:21:
Dolby Surround in case of this card (Dolby were never consistent with what they called "Dolby Surround") refers to the Dolby Pro Logic encoder, it's not really implemented by the card. I don't know of any technologies older than DTS Connect/Dolby Digital Live that would do something like that on the PC.
Looking at the manual, the "JVC 3D-Phonic Surround-Soundsystem" is a technology that tries to reproduce surround sound on stereo speakers (virtual surround sound). Something similar to Aureal A3D (and a dozen of other technologies). But it needs surround sound as an input, so I don't think it will work with plain stereo sound. Looking further in the manual, the drivers for Win 3.1 offer 3D-Phonic only as an option for the Dolby Pro Logic mode, what would confirm my suspicions.
For stereo expansion, this card has the "Texas Instruments 3D Stereo Enhancement" and this is a "spatializer".
This will be a fun card if you find something with a Pro Logic soundtrack. I'm not a movie wiz, but maybe there are Video CDs with such soundtracks. Will have to look through my parents Video CDs collection for Dolby logos 😉
getquake.gif | InfoWorld/PC Magazine Indices
