Reply 37020 of 38237, by torpedo_
HanJammer wrote on 2020-11-23, 23:47:
Here: https://psref.lenovo.com/syspool/Sys/PDF/with … book/mwbook.pdf - it may be helpful, although it may not contain the infor […]
torpedo_ wrote on 2020-11-23, 23:31:
This one arrived today. Still trying to figure out what model is this...
Here: https://psref.lenovo.com/syspool/Sys/PDF/with … book/mwbook.pdf - it may be helpful, although it may not contain the information about this particular monitor if it came as an element of larger system and was never sold separately. It may be then identified only by it's P/N which is 85H0764.
EvieSigma wrote on 2020-11-23, 23:39:
Looks like a POS system monitor to me...is it monochrome?
10" color, definitely not a Piece Of S... if you ask me (but yeah, perhaps some point of sale stuff) 😉))
Yup, it's a color screen. Max resolution 800x600. Now to find an exact model if possible 😀
Reply 37021 of 38237, by SVD
Some i already got but because of the overwhelming amount before I forgot about...
IBM 760ED missing powersupply... I can't seem to find a replacement. Proprietary 4 pin thing.
2x GA-60MM7E socket 370 boards with cooler and 1000mhz/133mhz PIII in each.
GA-6BX7 socket 370 board with 800mhz PIII
If I can get it to work with the VIA C3 nehemiah it is a contender for my all in one build 😁 can clock to 150mhz fsb. Don't know if it has the correct agp divider at 133 tho.
Reply 37022 of 38237, by torpedo_
SVD wrote on 2020-11-24, 18:33:
I'm using this adapter for my 760C.
Reply 37024 of 38237, by torpedo_
SVD wrote on 2020-11-24, 21:00:
Thanks. Where did you get that?😊
Previous owner gave it to me. He didn't have original power adapter, only this extension. No clue if it can be found on eBay or similar pages.
Reply 37025 of 38237, by bjwil1991
psychofox wrote on 2020-11-24, 11:54:
Todays find - SB 2.0 combined with IDE and floppy controller. Pretty rare card i guess? Unfortunately it has no sockets for CMS […]
Unfortunately it has no sockets for CMS chips 🙁
It's a beautiful card. It'll be perfect for a late 286 or 386 machine.
Systems from C64 to FX-6300.
Reply 37026 of 38237, by GL1zdA
HanJammer wrote on 2020-11-24, 15:25:
GL1zdA wrote on 2020-11-24, 12:09:
Nice find. I'm wondering where Avid used these cards. This one doesn't look like cards for video production, what Avid normally does.
Avid built complete system for video production. I guess it comes from one of these. Also it's cleary made by Creative Labs (even the typography seems familiar).
Yeah, I would expect it in one of their turnkey systems, but for what reason? The quality is definitely not for broadcast/production video, Avid used high-end AD/DA cards with big break-out boxes for this purpose. The copyright date (1991) is another interesting thing. In 1991 Avid's flagship product, the Media Composer, would still run on NuBus Macs, so it definitely wasn't used there. Maybe they used it in some utility appliance that just needed to communicate with the user and was so small, that the floppy and HDD controller had to be on a single card?
The font is indeed the one Creative used for their chips.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 37027 of 38237, by HanJammer
GL1zdA wrote on 2020-11-25, 08:27:
Another idea is that it was bundled with some of their software for consumer market.
They also sold re-branded SB Pro: https://www.amazon.co.uk/CREATIVE-Sound-Card- … d/dp/B009SFGBGK
Check out my AmiBay and eBay for ISA and PCI card, 286/386/486 Pentium motherboards and more.
Reply 37029 of 38237, by GL1zdA
HanJammer wrote on 2020-11-25, 09:15:
Never knew they basically rebadged Sound Blasters. Apparently the rebranded one is called "Sound Booster Pro" https://www.wavetable.nl/files/articles ... 20maak.pdf .
Reply 37030 of 38237, by appiah4
I haven't been buying much lately but came across these for $20 and couldn't say no even though I don't need them:
Prolink-Pixelview-Ge-Force2-Ultra.jpg Fastware-TNT2-M64-PCI.jpg Intel-Pentium-III-1000-B-B.jpg
I had a GeForce2 Ti but the Ultra is substantially more rare unless I am wrong. A TNT2 M64 won't set the world on fire but it's PCI so that makes it a good pick for some Socket 7 through Socket 370 builds. The P3-1000 was just a last minute throw in.
I also got these from @dreamblaster. You make awesomesauce stuff my friend.
I also bought a FIC FR33E mATX Socket 370 board to replace the PC Partner PM601TMS3-T898C I currently have in there. Both are PLE133T boards, but this one supports VIA C3 which I plan to use for a DOS/Win9x frankenstein build.. I'll post photos of that one later.
Reply 37031 of 38237, by Artex
EmpireOfScrap wrote on 2020-11-25, 10:29:
Not today, but last week or so
Pure GOLD! 😀
Click [here] to see my collection of retro bliss!
Click [here] to see my "I just gotta have it"' list!
Reply 37033 of 38237, by Aublak
More e-waste loot for $43
-MSI MS-4144 Socket 3 Motherboard
Its missing its BIOS chip, but there seems to be a dump on win3x.org. I'll see if I can program a chip.
Thank you, win3x crew.
-Winbound VLB IO card
-Trident Blade 3D
I just felt like I should own a terrible card.
-Trident Blade XP
confirmed broken upon closer inspection
-Voodoo2
has bad water damage on the back. Might be repairable.
-Geforce3
-Geforce256 DDR
-3x Tseng Hercules VLB
They all have rusty vga ouputs. I dunno how to replace vga plugs yet. Soldering them on shouldn't be a problem. Its just figuring out how to remove the rusty ones without damaging the pcb seems to be a problem.
-another Sound Blaster CT1350B
I suppose I have two now. The other one is a Rev. 4. I dunno which revision this is.
-Asus Geforce FX 5950 Ultra
Beautiful card. I pulled it straight from a computer. I just don't know what its good for. Its not really a win9x card and it doesn't seem to be an amazing winXP card when compared to later offerings. However, it is rare.
-3DFX Velocity
-2x Voodoo3 3000
only cards that I've tested and confirm working so far
-AEW32
some of the hackwork wiring that Creative did came undone. Should be easy to fix.
-Radeon 7500
at least I think so. Might be a 7000
-Promise Sata PCI card
should be useful
-S3 Vision968 PCI
Looks great, so I took it. Big lettering on the back; "Number Nine Visual Technology"
My PCChips M919 mobo that I posted earlier in this thread is working, but the ISA and VLB slots don't. Only plugging in a PCI video card works. Is there something I'm missing? Anything ISA doesn't work with it. Re: Bought these (retro) hardware today
appiah4 wrote on 2020-11-25, 12:48:
I haven't been buying much lately but came across these for $20 and couldn't say no even though I don't need them: […]
Yes the Ultra seem to be quite a bit rarer.
M64 isn't a bad card really. Yours is PCI and has a beautiful fan on it. I'd say its a keeper for its sheer utility.
    1.13 MiB
    1.39 MiB
    Loot 1
    1.2 MiB
    Loot 2
Reply 37034 of 38237, by appiah4
I didn't know Blade3D existed as discrete graphics cards..
Is that weird 3dfx card a Banshee or a Velocity 1000?
ALso, that Hercules VLB card that shoes only its back - what is that? Another Tseng?
Very nice haul. I am extra jealous of the super mint looking SB 2.0...
Reply 37035 of 38237, by Aublak
appiah4 wrote on 2020-11-25, 22:07:
I didn't know Blade3D existed as discrete graphics cards.. […]
I knew little about late Trident cards until I found one in a pile.
Yeah, its a Velocity
The Hercules showing its back looks the same as the card next to it, which is another Herc. The Hercules VLB in 'Loot 1' looks different from the two Hercules in 'Loot 2'.
Yeah, those early SB cards seem to be very sturdy. Every one I find is in perfect shape.
Reply 37037 of 38237, by GigAHerZ
Bought Samsung Syncmaster 213T, which is 21.3" 1600x1200 LCD for my retro machines.
Perfect 1:2 scaling for 800x600 resolution. For lower resolutions, it just has a buttload of pixels to use, so hopefully a good upgrade over current 1280x1024 19" screen. 😀
Reply 37039 of 38237, by GigAHerZ
SVD wrote on 2020-11-26, 11:13:
Perfect scaling is only important for LCDs. CRTs have variable pixel size 😀 So get an CRT 😉
Sure. CRT also needs a lot of space...
