Reply 37500 of 52890, by bjwil1991
Better photo (seller):
1.97 MiB
And it's a 486 socket with a 387 socket inside of it.
Reply 37503 of 52890, by chrismeyer6
Nice. I'm going to assume that it's for the vrm which should keep it running nice and cool. But it does limit your Isa card length for the two slots but it shouldn't be a big deal.
Reply 37504 of 52890, by imi
I don't think that board has a VRM, seeing how there's a 387 on it and the solder pads are unpopulated I'd assume the cpu to sit under that 😉
Predator99 wrote on 2021-01-06, 07:12:
Yes, you won the 1st price! :-D Good research work! […]
Ozzuneoj wrote on 2021-01-06, 03:30:
At first I thought that was an IBM PGA, but it's not. Has a lot of the same features but a lot of differences as well. What on E […]
Predator99 wrote on 2021-01-05, 16:59:
At first I thought that was an IBM PGA, but it's not. Has a lot of the same features but a lot of differences as well. What on Earth is it?
Is it a PGA clone?
Edit: I think I'm right... Is it a Vermont Microsystems IM-1024, which is an IBM PGA clone? Seems like the label on the back agrees, but I can't find a picture of one. That must be super rare!
Yes, you won the 1st price! 😁 Good research work!
Yes, I have been looking very long for a PGC card to fire the PGC input of my EGA-Monitor. However, as far as I can see, this one seems not to be suitable as it displays 1024x800 pixel and not 640x480 as the IBM PGC does.
Anyway, very nice card.
mhh that's a beautiful card nonetheless :3
Reply 37505 of 52890, by debs3759
imi wrote on 2021-01-07, 04:44:
It's a socket 1 486 board with a 387 in the 486 socket. If it's capable of taking a 386, it would be a QFP 386 in the unpopulated area top right.
Reply 37506 of 52890, by bjwil1991
The heatsink by the ISA slots houses a 386 PGA-132. The empty QFP can take either a 386 or 486 (usually occupied by a CPU in some cases).
Reply 37507 of 52890, by debs3759
Seems my assumption was wrong then. Never known a 386 to have a heatsink, let alone one so large 😀
Reply 37508 of 52890, by winuser_pl
I bought IDT WinChip C6 200 MHz for $10 incl ship. The processor legs are not straight, but the CPU itself is in working condition. My plan for the CPU is to fix the legs and get rid of that sticky glue from top.
The second item is the motherboard - Gigabyte GA-7N400S with yellow Socket 462 😁 It is brand new condition, but I/O ports cover is missing for some reason. It is nForce 2 mobo, supports Athlons, Durons, Athlon XPs and Semprons.
Price: ~ $9
    165.83 KiB
    1.62 MiB
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 37509 of 52890, by bjwil1991
debs3759 wrote on 2021-01-07, 06:32:
They must've put a heatsink on there to prevent the CPU from cooking itself if left powered on for hours on end.
I did find a heatsink fan combo for PGA-132 386 CPUs on eBay before, but it's been a while.
Reply 37510 of 52890, by Xicor
Yesterday, the "day of kings", I found a pc parts bundle @ 35€.
A mundane multi-IO VLB card:
1.3 MiB
.... And a horrible, yet missing in my "collection", OPTi 82c931 variant from Expertcolor:
1.29 MiB
A somewhat nice Aztech combo sound card, with licensed OPL:
1.83 MiB
And at last, the most interesting item was a rare Octek Hippo DCA2 motherboard (Am486DX4-100 included) :
1.59 MiB
The cherry on top was the 2 EDRAM simm's, 4mb only each, but better than none !!!!
Reply 37511 of 52890, by GigAHerZ
Ugh! MR BIOS! Please dump the rom!
Reply 37512 of 52890, by winuser_pl
I just received SO-DIMM 2MB SGRAM expansion for my Dell Optiplex GXa.
I paid 6 euros from electromyne Germany. I installed the memory into slot and it worked out of the box - 4 MB total of memory. Now the graphic card can do 1600x1200 at 16bit or 1024x768 at 32 bit. The problem is, the card output quality at 1600x1200 is a tragedy 😁
Also I wonder if put 4MB SO-DIMM would it work? It's ATI 3D Rage PRO
    1.2 MiB
Reply 37513 of 52890, by Xicor
GigAHerZ wrote on 2021-01-07, 12:49:
That was literally the first thing I did after removing the evil varta.
Here it goes, the dump of my rom (27c512):
Mr_bios_octek_hippo_DCA2_2.zip
45.3 KiB
53 downloads
Is there any use besides recovering another identical MB ?
Reply 37514 of 52890, by GigAHerZ
Xicor wrote on 2021-01-07, 15:15:
That was literally the first thing I did after removing the evil varta. Here it goes, the dump of my rom (27c512): Mr_bios_octe […]
As much as i've understood MR BIOS universe, then this bios is universal for all the motherboards using the same chipset. It doesn't have to be identical board itself.
But of course, it's also useful for people with identical motherboard but with non-MR BIOS on it.
Reply 37515 of 52890, by Big Pink
Managed to win this nice desktop/horizontal case on a certain well-known auction site.
Since I got my 19" rack I've been looking for something to house my current PC that will sit on the rack shelf better than the old Fujitsu tower. Most desktop cases out there are full ATX and beige, while the ones that aren't have low profile slots and only fit an SFX PSU - this meets my µATX + full height slots + ATX PSU + stealth black citeria.
It was obvious from the seller's photos there was some kind of P4 in there. Seems it was custom built with off-the-shelf parts in February 2004 to process security camera feeds to log number plates at some installation. It's a plain old Intel board in there (southbridge is ICH5 so north is probably an i865 variant) with two linked 'Neurodynamics Videomux' PCI cards. I haven't powered it up, though, because the capacitors are clearly bulging. No dust inside and it came in the original box, so I have to wonder if it was ever used for its intended purpose.
    41.45 KiB
    Seller's photo, fore.
    80.16 KiB
    Seller's photo, aft.
    167.04 KiB
    AGP 8x slot not visible
    16.54 KiB
    ANPR Manual
I thought IBM was born with the world
Reply 37516 of 52890, by GigAHerZ
Bought those new NiMH batteries for old motherboards to replace old and leaky NiCd batteries.
Reply 37517 of 52890, by bjwil1991
Huh. That's interesting. I was thinking about doing that myself for a few boards I have.
Reply 37518 of 52890, by mtgmackid
So on another ewaste trip I found a very sad looking PC XT:
Pulled it out and it was connected to a NEC Multisync JC-1401P3A still, and besides everything looking a bit dusty it's in good shape. I wound up getting the XT + NEC for a pretty good deal! Right now it's not syncing to the monitor but I'm suspecting the cable got damaged. Card wise it looks to be pretty standard.
Reply 37519 of 52890, by bjwil1991
Another 1980's computer and monitor getting rescued. This pleases me. The PC XT looks to be in pretty good shape for its age as well.
