The Yamaha OPL YMF718-S chipset.
Discussion about old PC hardware.
Re: The Yamaha OPL YMF718-S chipset.
Postby gerwin » 2011-10-11 @ 09:06
@Anonymous Coward
I opened up the SetupSA.exe in a text/hex editor and noticed the following strings:
"winpath" "winpath95"
system files mentioned:
"\system.ini" "\dosstart.bat" "c:\autoexec.bat" "C:\CONFIG.SYS" "CONFIG.BAK" "Himem.sys"
other files mentioned:
"opl3sa.ini" "opl3sa.bak" "OPL3SA.Drv" "test.ymh" "rec.ymh" "message.tbl" "SETUPSA.EXE" "SACDROM.SYS" "DWCFGMG.SYS"
You can maybe hexedit "winpath" to something else and force SetupSA to use opl3sa.ini instead.
It suggests there are two additional parameters instead of just /S:
/I and /M. Function unknown. Maybe /N too?
User avatar
gerwin
Postby Anonymous Coward » 2011-10-18 @ 00:04
I think the behaviour of the software must indeed vary according to which operating system is installed. When I have a moment I will attempt to hexedit setupsa as you have suggested.
Very interesting that you pointed out there are additional parameters available for setupsa. However, do to the poor documentation online, I doubt we will ever be able to determine what they actually do.
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby Nahkri » 2013-6-05 @ 14:14
I have a soundcard with the ymf 719 chip and under windows u can activate a softsynth wavetable.
Can u activate it under dos too?
Mb:JetWay 542C Ali Aladdin 5
Pr:Amd K6-3+:400MHZ @ 550 mhz
Ram:256mb
3D:Voodoo 3 3000 16MB
Sound:Turtle Beach-Montego A3dExtreme(Aureal Vortex 1)
Hdd:Maxtor Fireball Plus 8 40g,7200rpm,2mb cache
Os:Windows 98SE
User avatar
Nahkri
Postby gerwin » 2013-6-05 @ 14:31
Never bothered with the softsynth. Quite sure there is no DOS version of that software, DOS is not a good OS for making softsynths (as TSR's).
You might want to consider an Internal or External hardware synth.
User avatar
gerwin
Postby bristlehog » 2013-6-07 @ 19:15
Nope, the OPL3SAx (YMF719) softsynth is Windows only.
User avatar
bristlehog
Postby copados33 » 2017-2-13 @ 00:00
Does anyone know where I can get the W98 driver for this card? its an Addonics equipped with a Yamaha YMF 701-S OPL chip.
User avatar
copados33
Postby Deksor » 2017-2-13 @ 00:44
Go to yamaha's website ?
Deksor
Postby gdjacobs » 2017-2-13 @ 02:57
They've hidden all the access points but they mirrored it across when they updated their website.
http://device.yamaha.com/en/lsi/download/
User avatar
gdjacobs
Postby copados33 » 2017-2-13 @ 06:13
Thank you guys @gdjacobs
User avatar
copados33
Postby r00tb33r » 2017-3-12 @ 11:04
samudra wrote:Consequently I find out this card is made by Addonics Taiwan and find the generic drivers for this chipset on the Yamaha website.
http://www.yamaha.co.jp/english/product/lsi/download/index.html
Image of the config utility:
The website has changed and the chipset is no longer listed there, and no downloads.
I'd really like this utility. Do you know the file name or could you upload the driver package?
User avatar
r00tb33r
Postby gdjacobs » 2017-3-12 @ 11:56
Follow my link above. Yamaha just moved the files.
User avatar
gdjacobs
Postby r00tb33r » 2017-3-12 @ 12:48
gdjacobs wrote:Follow my link above. Yamaha just moved the files.
Thanks!
Got sound out of it, but sound effects in Doom are breaking up. Like some weird gargling effect. Synth sound is very pleasant however.
Is there something else I need to disable to fix the sound effects?
[EDIT]
Maybe it's reverb... It sounds awful.
User avatar
r00tb33r
Postby dries_86 » 2017-7-17 @ 18:05
Hi
I recently bought this card Yamaha OPL3SA2 YMF718-S.
I want to use it in a MS6309 Motherboard with 1x 16-bit ISA slot (slot is a little bit longer than the card but I guess this is normal?).
I reinstalled Windows 98SE and the card was automatically installed with WDM drivers, however no sound (headphones plugged in to speaker output).
Then I downloaded and installed the Yamaha drivers from Phils Computerlab, went very fast without problems. The device was then recognized as "YAMAHA OPL3-SAx Sound System" and I got some control panel but still no sound in DOS or Windows. I also ran the SETUPSA.exe in DOS (added to autoexec.bat) and it said correctly configured. No errors whatsoever.
What am I doing wrong because I'm thinking the Speaker output of the card may be broken (however it was sold as working) ?
dries_86
Postby dries_86 » 2017-7-18 @ 17:00
I checked with the vendor and he told me it's not possible to use headphones with this card. Only active speakers work in combination with this card.
Did not know sound cards like this exists..
dries_86
Postby gdjacobs » 2017-7-18 @ 17:32
I have a SB16 without the amp chip. So, same idea.
User avatar
gdjacobs
Postby dries_86 » 2017-7-18 @ 19:16
Ok so it's correct what the vendor is telling me and for my purpose (using it with headphones) I should find another card ?
dries_86
Postby gdjacobs » 2017-7-18 @ 23:18
Or run it through an amp.
User avatar
gdjacobs
Postby dries_86 » 2017-8-19 @ 10:51
I tested it on my Yamaha YHT1810 Home Cinema (suppose this qualifies as an amp) by a cinch/RCA cable and to the 3.5 mm SPKRS output on the card .
Looks like my card is correctly detected in Windows & DOS (can run SETUPSA.EXE and amend settings).
However still no audio output in Windows98SE (checked all volume settings-also advanced) or DOS.. Suppose this card is broken or am I doing something wrong?
dries_86
Postby greasemonkey90s » 2018-2-05 @ 23:26
Anyone have experience with the onboard variant ymf-701? My hp socket 7 pavillion has this chip with what looks like a ess daughter board with the actual speaker inputs.
greasemonkey90s
Postby gdjacobs » 2018-2-06 @ 00:07
dries_86 wrote:I tested it on my Yamaha YHT1810 Home Cinema (suppose this qualifies as an amp) by a cinch/RCA cable and to the 3.5 mm SPKRS output on the card .
If the setup works with another 1/8" audio source, yes you'd have to do some further troubleshooting. Know anybody with an oscilloscope?
User avatar
gdjacobs
PreviousNext
Return to General Old Hardware
Who is online
Users browsing this forum: chrismeyer6, Error 0x7CF, Google [Bot] and 18 guests
