First post, by diego gr
The only hint is the "AWE" chip, but it does not say if it is AWE32 or AWE64:
http://produto.mercadolivre.com.br/MLB-814434 … r-16-ct4380-_JM
The images are too bad to read the product numbers, but the card looks like a standard AWE64 card.
Yep, standard AWE64
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
you can read the sticker on the third picture, but you were correct of course, it says ct4380 awe64
Yeah, it's AWE64. The double row of AWE64's proprietary memory board connector pins gave it away.
Probably a AWE64 value.
Yes, CT4380 is the standard Sound Blaster AWE64. Thank you guys!
