swaaye wrote:The MPU port works fine in my experience, much better than the buggy Creative ISA card MPU ports. But since it's a PCI card, you need the card's ISA emulation driver running as with any other PCI card. The MPU port does work on port 330 in plain DOS and Windows with the driver loaded. .
I just had a play with my MX300 system, which has a DB50XG attached. If I select MPU 401 in the DOS MIDI section, then exit to DOS, then games like Heretic and Warcraft 1 clearly access the daughterboard at 330.
But in a Windows DOSbox the same games produce no music.
Is there a way to get the daughterboard running for DOS games in a Windows box?
Computer spec: Athlon XP2000, A7M266, 512mb ram, Voodoo 5, MX300 [did have SB128PCI in there but took that out, made no difference].
There is a multimedia device without a driver that I have disabled, but that's just a motherboard device. Reason I mention it is that I recall seeing a "multifunction adapter" device when I had a Vortex 2 before, though that was under Windows 2000.
