First post, by retro games 100
- l33t
I have been successfully testing some Pentium 1 CPUs. They range from P100 non-MMXs, to P200 MMXs. But when I inserted a P133 non-MMX CPU in to the mobo, and pressed the power switch on the back of the PSU (which doesn't turn on power to the whole PC itself), sparks came out of the PSU. I then realised that I forgot to alter the core/bus ratio jumpers on the mobo for this P133 CPU. So I fixed that, then turned on the PSU power switch again. More sparks. So, I take out the P133 CPU, and put back my last good working CPU, which is a P100. I reset the core/bus jumpers on the mobo for this P100 CPU, and turn on the power switch. No sparks. That's good. So I poke a screwdriver on the power pins on the mobo to get the power flowing. Power flows, mobo works, that's good. 😀
Anyone want me to fix your computer? Full refund if your house goes up in flames. 😉
