First post, by retro games 100
- l33t
VLB IDE IO controller = DC2000VL-2
HDD = old Seagate 450mb (approx)
CD = modern DVD drive
cable = old 40 pin
Usually this works: HDD + CD drive working together OK as master/slave. But not on this occasion, using this particular VLB controller. If I try and add a CD slave drive on the end of the 40 pin cable, the mobo won't POST.
(The VLB controller has 3 options for drive speed, and it only seems to work if I set this option to speed 2. Speed 0 and 1 don't seem to work.)
Has anyone had any problems using a VLB IO controller, with a master/slave configuration using a HDD and CD drive?
