First post, by retro games 100
HDD = very modern Samsung 300GB IDE
Overlay software = freely downloadable Seagate SeaTools for DOS.
Mobo = SYL8884PCI - EIO
Run overlay software. Using software, minimize HDD's capacity. I chose a value under 2GB, just to increase my chances of success.
Attach HDD to mobo's integrated primary IDE port using old 40 pin cable. I also slaved a DVD-ROM reader device off the same cable.
Mobo's BIOS auto detect HDD feature - finds HDD OK, but curiously the capacity seems a bit less than what I saw inside SeaTools. Oh well.
Power on 486 - BIOS sees HDD and boots from it, and also the auto/config files successfully initialize the DVD-ROM drive.
Run game (Dark Forces). All OK. Objective achieved: to use a modern HDD with an old 486 mobo.
So, overlay software to the rescue! Anyone foresee any potential problems?
Reply 1 of 7, by swaaye
You can get around drive size limitations with certain partitioning progs. For example, with XP and a 440BX mobo with a 160GB HDD, you can format it to 160GB even though the mobo can only see 137GB.
I've done this with 486s. You just need to figure out a partitioning app that can see all of the drive and make a FAT32 partition with it. Then it "just works". I think Partition Magic can do it. I'm sure there are linux apps on bootdisks that can do it too. Maybe even a XP recovery floppy/CD or install CD with diskpart onboard.
If you just want to make a small partition don't even bother with anything fancy. Just use DOS fdisk and be happy.
Reply 3 of 7, by retro games 100
GL1zdA wrote:
Could you do a test of the HDD with Speedsys and post a screenshot?
OK. Please see below. I ran the full HDD test.
    11.95 KiB
Reply 4 of 7, by retro games 100
That's interesting. Are you saying -
take a large modern HDD, attach it to "modern" mobo (so that its HDD controller can cope OK with it at "POST boot-up"), then fdisk this HDD using say a DOS 6 boot-up diskette, then detach the HDD from the "modern" mobo, and attach it to an ancient mobo:- then this ancient mobo's HDD controller will be able to cope with the modern HDD OK? If that will work, then I guess there's no need to use overlay software.
Reply 5 of 7, by GL1zdA
Thanks. Does anyone know, whether it is possible to tell, how much bandwidth the HDD controller has based on the Speedsys test ? (linear read speed?) A fast modern HDD should be able to saturate it with ease, so it might be possible, to find the limit.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 6 of 7, by swaaye
Basically yes. But you should be able to find a partitioning program that will do the partitioning of the large drive even on the 486 mobo.
I've done this myself on my PCI 486 with a 8GB limit. Probably used Partition Magic.
The BIOS may not recognize the size, but the OS such as 95C seems okay anyway.
Reply 7 of 7, by swaaye
I think 486 PCI usually manages about 20MB/s. Part of the problem is poor DMA busmastering support so the CPU is quickly maxed out and part is that there just isn't much bandwidth to go around on a 32-bit 486 mobo.
Any 7200RPM desktop drive made in the past 9 years should be able to manage a linear read rate above 20MB/s. Newer 5400s too I'm sure.
