May I also ask what OS you are using? With my 8KTA3 and Mobile Barton, I have successfully enabled the halt states in a number of ways, with Cool-On, wpcredit, and such. Sometimes I can see that there is a definitive, marked improvement, and then after an undetermined amount of time it freezes. The other times it simply freezes right away! Based on posts that I have read, there seemed to be two theories as to the cause. One said that it had something to do with the OS, with people stating that they didn't have a problem in 98, and that NT based OS's did. I also saw another one where there was speculation that it was a motherboard issue, specifically the voltage regulators not being able to handle the huge swings in power draw as the processor switches in and out of the HLT / Bus disconnect modes. I really wanted to get this working since my machine is left on... well pretty much constantly. In my current configuration, my processor is under-volted from the original Athlon XP spec of 1.65 to 1.475. During idle it usually hovers around 41-42, and even while under full load it rarely tops 50. However, after one particularly long run with the cooling on it crept all the way down to 34.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
