First post, by retro games 100
CT2760 rev 3, the "funny" one with some physical jumpers, that also uses setcard.exe utility to mess about with its other resources. Stick on a waveblaster2 to its wavetable header, run Dark Forces, and it crashes with a stack overflow. Also, I tried a Yamaha clone DB, and the music sounded weird. I abandoned the AWE32's wavetable header, and just used this card for digital effects, and mounted both daughterboards (one at a time of course) on to a Roland 401-AT card, and the music worked fine.
I wonder if the CT2760 rev 3 has a buggy wavetable header? It seemed OK for some games, but not others.
Reply 1 of 3, by aleksej
Dark Forces sound support is a piece of shit. It lockups with many famous soundcards used as WT daughtercard host, not only Creative products. Yeah, authentic controllers by Roland works ok with it, surprize!
Reply 2 of 3, by swaaye
what are you doing in your config.sys and autoexec.bat? And what does this system consist of?
I've played the game successfully with SB16+SCD15, AWE32 and with lots of Ensoniq cards.
Reply 3 of 3, by retro games 100
I have sinced "moved on" from this testing, but from memory recall, my DOS 6 config and auto files just contained the bare minimum - I even asked DF's setup utility to make me a boot disk, which was very basic.
Apart from the usual SET BLASTER line, I had a diagnose /s line (and also no aweutil /s line.) Perhaps the wavetable header was acting strangely because I used setcard.exe to alter the base memory address to 300H, because the Roland 401-AT card was using 330H. Maybe that threw a spanner in the works?
I've got a fair number of Creative SB16s / AWE32s, and this is the first time I've seen this problem. The AWE32 in question was OK, so long as I only asked it to do the sound effects, not DB wavetable music + effects.
The machine in question was an Asus socket 7 board (P166mmx) - a TXP4X rev 3.01. I must admit that it behaves a bit oddly from time to time - on POST, sometimes you see weird characters on the screen.
Actually, I'm happy with the AWE32 (effects) + Roland 401-AT with DB wavetable (music) configuration. That was the route I was going to take - I just posted my O.P. topic because it seemed a bit unusual.
