I made a few changes to the KT133A based set up, but unfortunately it hasn't made the 3DMark 2001 s.e. score any better.
I removed the QDI Kinetiz board, and replaced it with an Abit KT7A board.
I removed the Infineon 256 MB SDRAM stick, and replaced it with a 512 MB SDRAM ("no name/brand") stick. Reading prophase_j's post above, I think the best thing I can do is to get a stick of "CL2 SDRAM".
I made some BIOS set up area changes (from prophase_j's post above) - First load optimized defaults, then set "Fast RW Turnaround" = on, and also set "CPU command decode" = fast. I also set the AGP aperature from 64 to 128.
The 3DMark 2001 s.e. default settings score is now 7845, which is actually less than the score obtained on the QDI Kinetiz board, which was 7928. Without changing the SDRAM, I don't think that I can get this value to significantly improve..
I might try another graphics cards in this Abit board. Also, I might be able to get another Ti4200 to test. Hopefully tomorrow. This one is by Gainward, and a review can be found here -
http://www.bjorn3d.com/read.php?cID=73&pageID=161 (Page 2 of 2)
What's interesting is that this test shows a 3DMark 2001 s.e. score of 9652. The test rig includes:
* AMD Athlon XP 2000+ (I am using a t-bird 1400 mhz CPU)
* Leadtek K7N420DA nForce motherboard (I am using a KT133A Abit board)
* 2 256MB OCZ PC3000 DDR RAM (I am using 1x512 MB of "crappy" PC-133 SDRAM)
