First post, by ux-3
I have just made some odd observation. When using a classic Tseng ET4000AX, warlord2 music plays normally during load. When using an S3 VLB card (miroCRYSTAL 8S) the music hangs/pauses briefly, when a new screen is loaded or build up. It does not matter if FM or DB is selected. The music does not interrupt, it merely holds its tone for perhaps 0.25 seconds, then plays on. Removing the IRQ2 setting on the S3 does not help.
Is this effect known? Is there a solution other than using the Tseng?
