F2bnp wrote:Hey guys I got a Biostar M7VKD with the KT133A chipset. The Barton Mobile CPU is going to work fine on that one right?
Hmmm...interesting! I have never tested a Biostar M7VKD mobo before. I see they've got support for it on their website:
http://www.biostar-usa.com/mbdownloads.asp?model=M7VKD
It mentions a 2002 dated BIOS supporting XP 2100+ rated CPUs. The Epox mobo, on the other hand, has a May 2003 dated BIOS which supports the T-Breds and also doesn't complain if you use a mobile barton. Also, the QDI Kinetiz mobo has a 2004 dated BIOS which works OK with T-Breds and mobile bartons. I also believe the Abit (rev 1.3) board supports these high end Athlons too. But the Biostar's final BIOS revision of 2002 seems a bit old to me. It's possible it won't work with a mobile barton. You're best bet, I think, is to try a very cheap mid-range T-Bred CPU in it. If it works, then great, you may be lucky with a mobile barton. If it doesn't work, then a mobile barton probably won't work.
