First post, by bushwack
Windows 95 has Dosstart. What does Win98 have?
I'm building a test machine and I can't remember how to edit (or find) the autoexec/config file I need to add mouse drivers, ect. when I exit win98 into DOS.
Reply 3 of 7, by bestemor
Just start 'msconfig.exe' (when in win98), which is found in the C:\WINDOWS\SYSTEM/ folder. The tabs would then explain which is which. Edit at will!!
(I 've made a shortcut to desktop for it 😁 )
PS; the autoexec.bat and config.sys are also found directly under C:\
At least I can see them there, both in DOS and win... 😎
Reply 5 of 7, by bestemor
Maybe I'm not getting this, but WHY do you need this 'dosstart' thingie ?
You edit in your mouse and CD driver lines directly in the autoexec file, or...?
(confused)
What is written in the autoexec.bat file, when you open it ?
