The Iwill gave me data corruption (read errors in DOS where it asks you to retry, abort, or something like that..). I tried PIO mode instead of DMA but the issue didn't go away.
Put the 440BX back in the box and all is good. I won't be trying to fix the Iwill though, enough cheap parts around to have fun with 😀
The Aopen AX59 Pro is a nice board, but doesn't have a L1 setting in BIOS. And ICACHE or ICD only work on the Cyrix and Intel and not on the K6...
So I have a Pentium 200 underway and that should be nice to complete my "timemachine sheet" with some more slowdown results...
EDIT: Well this is odd. 440BX system is fine, so I tried the other SS7 board and I get the same read error again. Weird though, it's always at the same spot (during running autoexec.bat when it's loading AWEUTIL or CTCU for the AWE64)...
So far only the SS7 boards had this issue. I havn't seen it on the 440BX.
