EDIT: Let me clarify...
I can select General Midi and it works.
But selecting the Soundscape option doesn't do anything (at least when I use the test)...
Yea I found all 3 ecw's so all good!
It's soo funny listening to Monkey Island 2 as this cards substitutes FM synth with wavetable sounds 🤣
EDIT: I checked the E-MU site and they do have drivers but only for windows, not for DOS. The 2 and 4MB sets are there as well!
EDIT EDIT: Well the ecw's work great. There is a ini file which I just change to tell it use the other ecw's 😀
mem/c even reports that more memory is used 😀
Doing a recording for 2, 4 and 8MB with Dark Forces (The same Intro you did but with SB turned off) and also Doom E1M1...
EDIT EDIT EDIT: Well I am making progress...
The Star Wars tune is quite interesting. One one hand it's quite complex on the other hand it sounds good even on the cheap wavetable options.
Are there any other Games that support MT-32, General Midi, native GUS, native AWE and have interesting music with maybe "less going on"?
Doom music is quite simple, so you can realy concentrate on how the indivual instruments sound. Dark Forces is a full blown orchestra and I struggle to seperate instruments...
