First post, by ACSK
I have a Tyan Tomcat motherboard, and the manual states the following:
The front panel on your case may have a turbo switch to control system speed when slower program execution is required for software developed in the old XT days. The Intel 430HX chipset doesn't support a de-turbo mode, but the S1562 has a connector for the cable that may come with the case.
What does that mean? The motherboard has a connector, but it doesn't do anything? Or is it just poorly translated?
The board does have turbo switch and led connectors. (in fact the original case was wired to read-out 133MHz, with 33MHz as the 'de-turboed' readout (which I'm pretty sure is inaccurate, anyhow). Right now a 200MHz processor is installed.
Anyways, I'm just trying to figure out what, if anything, the 'turbo button' does on 430HX based systems. Any light that can be shed on this would be much appreciated.
