AWE64 and DOS/ Win98
First post, by gwb
Hello all, long time reader, first time poster.
I am currently building a system equipped with a SB PCI512 and a SB AWE64 gold. I was able to get the PCI512 installed and working with my modern Windows games, ex Quake3. The problem is that I can't seem to get my AWE64 working for some reason with older games (Doom2 and Warcraft) or newer games. I used the driver that was in the sound blaster driver pack uploaded by a member here on the forums.
The AWE64 resources in the device manager read
IRQ7, DMA3, DMA7, I/O range 0240-024F, I/O range 0300-0301, I/O range 0388-038B
My BIOS is set to non PNP OS
My config .sys reads
[menu]
Menuitem=windows, Windows 98SE
Menuitem=dos, MS-DOS
menudefault=windows, 8
[dos]
DEVICE=C:\Drivers\jemmex.exe NOEMS I=B000-B7FXX
DOS=HIGH,UMB
DEVICEHIGH=C:\Drivers\OAKCDROM.SYS /D:MSCD0001
DEVICE=C:\AWE64\DRV\CTSB16.SYS /UNIT=0 /WIN95 /BLASTER=A:240 I:7 D:3 H:7
DEVICE=C:\AWE64\DRV\CTMMSYS.SYS
LASTDRIVE=Z
[windows]
DEVICE=C:\WINDOWS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /Q
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE AUTO RAM NOEMS
LASTDRIVE=Z
Autoexec reads
@echo off
prompt $p$g
goto %CONFIG%
:dos
SET SOUND=c:\AWE64
SET MIDI=SYNTH:1 MAP:E MODE:0
SET BLASTER=A240 I7 D3 H7 P300 E640 T6
LH C:\Drivers\ctmouse.exe
LH C:\Drivers\SHSUCDX.EXE /C /D:MSCD0001 /L:D
goto end
:windows
win
goto end
I was able to get Doom2 playing with music, but no sound effects for some reason using the aforementioned specs
Reply 1 of 50, by dosquest
Doom uses separate settings for sound effects and music, your best bet is to check the setup.exe for doom and see what you set for the sound effects versus the music.
Reply 4 of 50, by gwb
I am not seeing that option. It only asks for the music card and the sound FX card. Under sound effects it list the following devices "Ultrasound, Pro Audio Spectrum, Sound Blaster, and PC speaker."
Am I looking in the wrong area?
Thank you for your help!
Reply 6 of 50, by gwb
I did not have diagnose.exe for some reason so I downloaded it from this thread (Different Versions of Mixerset and Aweutil...) and put it in my awe64 folder. I got to the option of selecting the base I/o and it gave me the same "check whether the base I/O address selected corresponds to that of your audio card" error. The I/Os I tried were 220H, 240H, 260H, 280H, and auto.
Thanks
Reply 7 of 50, by Gamecollector
Not 100% sure, but it looks like your's AWE64 is simply not initialized in the DOS.
You need to download/install the Creative PnP Manager (from AWE64 Gold cd or from support.creative.com). It add "device=C:\...\ctcm.exe" string in the config.sys and "set ctcm=" + "c:\...\ctcu /s /w=" strings in the autoexec.bat.
Reply 8 of 50, by gwb
Okay I think I am making a little progress here
I reran diagnose.exe in dos mode and got the results
Base I/O on 240H
Wave-table 640H
Usable DRAM 4194304 bytes (tested okay)
MPU401 MIDI 300H
The next part is the IRQ scan and it fails on all of the following IRQs 2, 5, 7, 10, and auto
Config.sys looks like
[menu]
[dos]
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\CTCM.EXE
LASTDRIVE=Z
[windows]
DOS=HIGH,UMB
LASTDRIVE=Z
And autoexec is looking like
@echo off
prompt $p$g
goto %CONFIG%
:dos
SET CTCM=C:\WINDOWS
SET SOUND=c:\AWE64
LH C:\WINDOWS\CTCM.EXE /S /W=
goto end
:windows
win
goto end
Doom2 does not play any music or sound effects and Warcraft does not want to recognize my cards
Thanks again!
Reply 9 of 50, by Mau1wurf1977
Boot into DOS and press F8. Say no to everything...
(I'm assuming you are running this from real DOS and not from a DOS windows from inside windows)
Go into your windows folder and run CTCM.EXE
Then go into your AWE64 folder and run AWEUTIL.EXE / S
If the files aren't in these folders do a search for them and run them from wherever they are.
My YouTube channel
Reply 10 of 50, by gwb
Boot into DOS and press F8. Say no to everything... […]
Alright, I did a clean boot and ran CTCM- no problem there. I then tried running aweutil.exe and it gave me the following error
ERRO12: AWE32 initialization failed
Thanks
Reply 11 of 50, by Mau1wurf1977
Set BIOS to PNP OS and there should be also a setting "Clear DMI or something on those lines".
What did CTCM output?
My YouTube channel
Reply 12 of 50, by gwb
CTCM output is as follows
Found Creative Plug and Play card  : Creative SB AWE64 Gold
Successfully configured 3 of 3 Creative PLug and Play Devices
Blaster environment is set at: A240 I7 D3 H7 P300 E640 T6
I changed to a PNP OS in BIOS. Did not see a clear DMI setting, but I saw a "Reset Configure Data" and it apparently "resets Extended System Config Data (ESCD)" and I still got the same result
Reply 13 of 50, by Mau1wurf1977
That looks very odd... The resources are totally "non standard".
Do you have another card in the machine? Can you pull it out?
My YouTube channel
Reply 14 of 50, by gwb
I agree, they do look odd to me. I have the PCI512 in the machine and removed it and still got the same errors and settings. I tried it with PNP OS enabled and disabled and cleared the ESCD. The only other card is an AGP video card
Reply 15 of 50, by retro games 100
Just a couple of thoughts. This is what I would do, but I'm not sure if it's the best approach -
Do you have a DOS HDD / CF / diskette you could boot from? If so, you could boot in to "real DOS" (not DOS 7), and run Creative's CTCU.exe. CTCU will only run in DOS 6 or an older version. Then, take a look at the AWE64's resources. If they are non standard, you could alter them to something like 220/5/1/5. After doing that, go back to your Win98 installation, and then in the Windows device resources section for the AWE64, do a "force hardware resource change", and make the settings also equal to 220/5/1/5.
BTW, once you are back in Win98, you can remove any reference to CTCU in your config files, if there are any there.
Edit: Damn, perhaps I'm thinking of how to configure the PnP AWE32. Maybe just try a force Windows hardware resource change for the AWE64's resources.
Reply 16 of 50, by Gamecollector
Reserve the irq7 in the BIOS.
Advanced/PCIPnP and change "avaiable" to "reserved" for irq7.
Then - try ctcm and diagnose again.
Reply 17 of 50, by Mau1wurf1977
That shouldn't be necessary. I believe this is for non PnP ISA cards so that the IRQ doesn't get assigned to another device.
Another though!
After running CTCM run CTCU and assign the default configuration. Maybe that fixes your issue...
Reply 18 of 50, by gwb
Okay so I made a 6.21 boot diskette and booted from that. I then ran ctcm and it gave me the normal settings (see below)
Blaster environment is set at: A220 I5 D1 H5 P330 E620 T6
I am still trying to get ctcu to work as I post this
Reply 19 of 50, by Mau1wurf1977
Thats much better!
Now run AWEUTIL.EXE /S
My YouTube channel
