Reply 20 of 73, by rick12373
- Oldbie
wrote:Afaik most 486's seem to actually be quite easy to overclock, especially if you have a board that supports the "magic jumper", meaning it can halve the PCI bus compared to the FSB.
However, even though the 133Mhz chips (which are usually AMD 5x86's)If you want good fpu performance, maybe a Pentium Overdrive wou8ld be a good idea?
I will look at board when I get home. It sounds like it will be challenge for my level of knowledge though! Maybe somebody here has experience of overclocking on this motherboard?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
