Reply 20 of 79, by Markk
- Oldbie
I have the same multimeter! (almost... mine is identical but with a different maker label). Yes, you have to switch on the board to measure. I would recommend to take a molex power connector and plug the black wire of the mm into one of the two middle holes of the connector that are leading to a black ground wire from the psu. Then you can touch each one of the pins on the ps/2 header with the red cable of the mm, and when you read around 5v on the screen, then you know which pin is that. After that, you do the opposite. Plug the red wire to 5v on a molex, and with the black touch the other pins (be careful. Avoid to touch those that you found that are the 5v ones), and that way you can find which of the pins are ground.
