First post, by bestemor
- Oldbie
So, how do you partition these things easily ?
I couldn't even get PartitionMagic 8 to recognise it's presence, even when it was showing as 'disk' E in the WinExplorer (granted, XP labelled it a 'microdrive', but).
And, when reformatting I had to use the native WinXP menu(properties etc) instead (never done that before). Which had pretty limited options.
Normally I use PM8 for all this stuff, so...
Is PM8 too old for this type of hardware ?
Haven't tried using DOS commands yet(or assembling it as a bootable machine), so not sure if that'd work - but even so I'd prefer a modern GUI.
What software do you use to partition these things, if at all possible ?
Another problem I suddenly discovered, was that the adapter I bought from HongKong some months ago had a serious flaw - the 2 plastic guide rails was not of equal size ! WTF ?
One was the thinner version, which allows for modern CF cards, but the other was much thicker - meaning I could only fit the older actual microdrives(those that really are miniuature hard drives) in the slot... 😒
Even so it seems that my Seagate 2,5GB 'for embedded apps only' disk is a dud, or at least useless as a hdd (is not found at all).
So, anyone have some insights here, having done something similar themselves ?
(ultimate goal is a socket7 DOS/win box - got an AT abit board with softmenu, 100-233mhz range just a reboot away)
