Tillamook
First post, by SquallStrife
I purchased a CPU for a dollar from another forum I frequent.
It's a 233MHz Tillamook, with a 1.9v core voltage.
Trouble is my PC Partner motherboard's lowest official voltage is 2.7v.
So I guess my question is: If I attach a decent cooler, will the CPU survive being run at 233MHz at 2.7v?
Reply 1 of 76, by luckybob
its supposed to run on 2.8v ^.^ go nuts!
Reply 2 of 76, by Old Thrashbarg
The fact that it specifies a 1.9V core voltage would imply that it's not supposed to run on 2.8V. And given that the Tillamook uses a smaller process than the regular P55C chips(0.28u versus 0.35u), it's likely to be considerably more sensitive to voltages, too.
I think it would be a very bad idea to try it. You could probably get away with 2.2 or 2.3V, but 2.7V seems pretty dangerous even with a good cooler.
Reply 3 of 76, by luckybob
oh i was thinking the desktop chips...
the v I/O is also 2.2V on the tillamooks... yea your not going to be able to run a mobile processor in a desktop board. not any desktop board i've ever seen.
Reply 4 of 76, by DonutKing
So does this Tillamook come in a PGA package? All the tillamooks I've seen (all 1 of them 😜 ) are mounted on a board with the connector in two rows rather than pins.
Can't answer your voltage question. I'm currently running a 3.3V DX4-100 at 5V and its been going for a month without exploding (touch wood) although that's not really relevant, since the larger manufacturing process of the 486 is probably more tolerant to higher operating voltages than the Tillamook,
Reply 5 of 76, by SquallStrife
http://i.imgur.com/7kyBW.jpg
It's the bottom left chip. I checked it out on cpu-world and it's definitely Socket 7, just 1.9v and apparently useless.
Oh well, it was only $1. 😜
Reply 6 of 76, by luckybob
there's no way you are going to get a cooler on that chip... not with those caps on the top. its still a cool chip! all you need to find is a motherboard that have a 1.8v core support and lets you have a heat sink under the socket. 😜
Reply 7 of 76, by iulianv
he could try to place a small piece of metal (like a lapped coin) between the CPU and the heatsink, in order not to disturb the caps 😀 using thermal grease on both sides, of course...
Reply 8 of 76, by GXL750
I used to have a 233mhz chip in that same style pulled from an old WinBook. The chip I had, however, had heat spreaders on top and under the cpu that were held on by two screws and I had no trouble putting a heatsink on the chip.
Reply 9 of 76, by Tetrium
There are Tillamooks that came in PPGA package (the black package that the later Pentiums and easy PGA Celerons came in), they look exactly like the Pentium MMX's except for the print on the bottom between the pins.
They should work in Super 7 boards, but theres no guarantee they will work
Edit:It's sspec is SL2Z4 btw 😉
Theres 1 seller selling them for $20 each or so? Not very cheap but at least they are available
Edit2:
Pic (not mine): http://www.chipdb.org/img-intel-pentium-fv805 … -sl2z4-1284.htm
My retro rigs (old topic)
Report spammers here!
Reply 10 of 76, by SquallStrife
Guess what guys?!
Motherboard thanks to DonutKing.
Reply 12 of 76, by SquallStrife
It is a PC Partner VIB876S, VIA MVP4 chipset.
Manual: http://www.pcpartner.com/support/man/via/887602.pdf
I used the clock and ratio settings for a normal 233 MMX, but used the 1.9v setting from the end of the manual.
Reply 13 of 76, by sliderider
You may have just started a trend of putting mobile CPU's in desktop boards. Everybody is going to be trying it now.
Reply 14 of 76, by prophase_j
I ordered one of these a week ago, I bet it will take 300mhz easy with little bump to the volts, and I have heard rumors they can work at 400. I strongly suspect that all of the non-tilly pentiums are in fact at the .35u process, since it is only these mobile ones that take the 1.9v setting, indicating that they use .28u, which will be much more overclocking friendly.
Honestly I'm surprised no one else in the 300mhz thread has picked one of these up, as popular as that project became.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 15 of 76, by sliderider
Has anyone seen a 300mhz that fits in a s7 motherboard?
Reply 16 of 76, by Tetrium
Don't think they exist.
Btw, I do have a Tillamook rig planned, but it hasn't come to actually building it.
I got 3 Tillamook 266's waiting to be tested first 🤣
Reply 17 of 76, by Mystery
Does your MVP4 board automatically disable the L2 cache, or is it still active? Could you test it?
Because the MVP3 chipsets won't boot with the 266 Tillamook until you disable the L2 cache, which makes the overclocking possibilities of this CPU (400MHz is doable) null and void, because the performance is terrible.
::42::
Reply 18 of 76, by SquallStrife
OK, so I got a "You might have FAKE CHIPS" message from CACHECHK on the PC Partner motherboard... but check this out:
The new motherboard is a Jetway (?) J-TX98B. It has an integrated CMI8330 !!!!
Also, the CPU runs at 2.1v no issues. This board doesn't appear to do 1.8 or 1.9v.
