Power supply problem
First post, by Sugoll
Hi, I just saved an old Compaq Prolinea 4/33 from the scrapyard, but there's a problem with the on/ff switch: it doesn't seem to work anymore.
This switch is located on the front of the machine, and there is a fat black cable with 5 thinner cables inside leading to it from the PSU (the PSU doesn't have a switch).
Now when I plug in the power cord the system does turn on briefly, so I know the PSU itself isn't dead.
Does anyone know how to fix this?
Reply 2 of 10, by Sugoll
I meant it more like: does anyone know how to fix the power switch? I'm pretty sure that's where the problem is 😀
OR a way to the PSU on without using the power switch.
Reply 3 of 10, by megatron-uk
Sounds like an AT PSU... you'll have to fix the switch - an ATX PSU can be switched on via shorting two pins in the large multi-way plug, but this is not possible with the AT spec.
https://www.target-earth.net
Reply 4 of 10, by 5u3
From the description it sounds like an AT PSU alright, which means that the cable (and the switch) carry mains power when plugged in. Do not try to fix this yourself if you don't know exactly what you are doing.
BTW, if the switch on an AT PSU is really broken, the PSU wouldn't turn on at all. The fact that it comes alive only for a short moment rather indicates that the problem is somewhere else.
Reply 5 of 10, by Tetrium
^Yup
And frankly, I wouldn't try this myself. the AT PSU's are not really irreplaceable as there are ATX2AT adapters to be had for like €10 or so. Use one of those with a (very affordable) 250W ATX PSU of good manufacture
My retro rigs (old topic)
Report spammers here!
Reply 6 of 10, by megatron-uk
An ATX PSU and adapter cable is definitely the way to go if you don't know what you're doing..... as long as the Compaq takes a standard sized power supply - Compaq machines of that time are similar to the Dell machines of today!
Reply 7 of 10, by Sugoll
Thanks for the replies so far. Frustrating that something seemingly so simple is beyond my powers to repair. Tried fiddling with it this afternoon and got zapped. No more of that 🙁
Too bad, because it is such a nice machine, with the Tseng ET4000/W32p on-board and an AMD 586 133 MHZ overdrive proc.
Reply 8 of 10, by Tetrium
Are you absolutely sure it uses a non-standard PSU pinout?
And even if it does, that doesn't mean it's impossible to mod an ATX2AT adapter to fit it 😉
Edit:And be extremely careful when fiddling with the insides of any PSU!!! This includes the AT power switch, it could be hazardous both to your home and yourself!!!
Reply 9 of 10, by Sugoll
No, i'm pretty sure it's standard (2x6 pins). I'm just not a big fan of modding vintage stuff like this 😢
But I guess i'll have to if I want to get this to work.
Reply 10 of 10, by SavantStrike
You'd better!
133mhz overdrive chip. Woot!
And I second what 5u3 said. Take the power supply out of the machine entirely, place it on a non conductive surface (wood, tile, something), and plug it in. If the fan turns on in the power supply, your problem lies elsewhere. Also, make sure the switch is in the "on" position before you do this, and maybe plug the thing in from the wall socket side of the power supply rather than the power supply end if you're worried about getting shocked.
