First post, by Svenne
Hello!
I recently aquired two Pentium IV-based computers; one with an Epox mobo, and one with an Intel mobo. The one with the Epox mobo works fine, though the one with the Intel mobo just shut off itself when I turned it on. I still kept it, thinking that it might be BIOS related or similar. After some time I decided to take a look at it again, and it turned out the problem was a faulty PSU.
However, the case it was mounted in had it's sides missing, so I moved it to another one. Stupid as I am I forgot to memorize where the cables were connected, and now it refuses to boot; it starts, but then it just sits there doing nothing. Anyone know what I might've done wrong?
Here are some pictures I took. Sorry about the horrible quality, but I didn't have access to a camera at the moment.
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 1 of 8, by elfuego
Lame question but, have you connected the VGA cable? 😀 Since it starts, you connected the 'start' contact good so if you also connect PC speaker (red and black cable) to the right pins (check the MoBo manual) put an ear to the speaker and look for beeps. Also check if the video card sits ok in the slot.
Reply 2 of 8, by leileilol
The motherboard pics aren't clear itself... so I don't even know if it has onboard video. If it does, plug in the monitor to the onboard VGA out first, then hop into the BIOS, set it to initialize the AGP card, then save/quit then move monitor cable over
Reply 3 of 8, by BigBodZod
Best trick to try out is this:
1) Remove all the expansion cards including the graphics card etc...
2) Remove all the RAM/Memory modules....
3) Leave only the PS Unit and CPU installed/connected....
Now power on and see if you get an POST beep errors.
Could be a faulty memory stick or something on the motherboard got zapped by that previous PS Unit you said was faulty.
Also make sure that if that P4 board has a 4-pin AUX power connector to use it, some PS Units do not have this cable so you have to use MOLEX to AUX power adapter cables instead 😉
No matter where you go, there you are...
Reply 4 of 8, by Tetrium
Best thing to do in cases like these is to put the board on a flat cardboard box and start testing with the basic minimum.
My retro rigs (old topic)
Report spammers here!
Reply 5 of 8, by sliderider
Here's a question. Are the motherboard or the case proprietary? If you're using a Compaq, Dell, HP, etc motherboard or case then the voltage from the power supply may not be compatible. There was a period of time where they used unique voltages that don't work with standard ATX power supplies or motherboards that work with standard ATX supplies.
Reply 6 of 8, by Tetrium
sliderider does have a point worth investigating. I know Dell uses proprietary PSU's in their P3 ATX boards. Can't comment on their pre-ATX stuff but I reckon those use normal PSU's.
I know that at least "some" compaq P3 boards use the standard ATX PSU wiring (or I would've seen smoke 🤣).
I don't know about HP, so far I never had one with non-standard wiring.
Will go look up some stuff and see what I find 😉
Edit: Lots of info here: http://pinouts.ru/pin_Power.shtml
Reply 7 of 8, by SavantStrike
sliderider has a point, but so does Tetrium.
If you know you've got a compatible power supply, and you're not having a conflict with onboard video, and everything is hooked up okay yet it still won't power on, then you've probably got a short 😀. It can happen if the stand offs aren't tall enough and/or the board isn't in the case right.
I'd check for the power supply and video problems first though, and then I'd reset the cmos. If that doesn't work then make sure the board is in right.
Reply 8 of 8, by Svenne
I did some experimenting, turned out the video card wasn't seated properly. I fixed it by loosening the motherboard screws, re-inserting the graphics card and then tightening the mobo screws. The computer works perfectly, besides that the CMOS gets reset if the PSU is disconnected. I'll have to get a new battery it seems. Thanks a lot for the help guys!
