The Ultimate 486 Benchmark Comparison
Re: The Ultimate 486 Benchmark Comparison
Postby Intel486dx33 » 2019-1-19 @ 19:26
Benchmarked my AMD 5x86-P75-133 over clocked at ( 4x40mhz = 160mhz ) computer.
64mb ram
540mb WD HD
256kb cache
Mobo - PCChips 918i ( ALI Chipset ).
User avatar
Intel486dx33
Postby Tertz » 2019-1-28 @ 03:13
Intel486dx33 wrote:I want to benchmark my AMD 5x86 ( 4x40mhz = 160mhz ) computer.
What are some good benchmark tools for readings ?
speed test
dhrystone
Just curious as "Minimum requirements for Win32 port to run are minimum requirements for Windows 9x and SVGA card". 1st part there, at least
dosbox
Tertz
Postby Intel486dx33 » 2019-1-31 @ 06:26
Intel486dx33 wrote:Benchmarked my AMD 5x86-P75-133 over clocked at ( 4x40mhz = 160mhz ) computer.
64mb ram
540mb WD HD
256kb cache
Speedtst benchmark = 561721
Dhrystone / seconds = 38558
Done.
User avatar
Intel486dx33
Postby Intel486dx33 » 2019-1-31 @ 06:27
More photos
User avatar
Intel486dx33
Postby Tertz » 2019-1-31 @ 22:53
Intel486dx33
You may be the 1st to enter the data about 486 speed of emulation in DOSBox. We need a hero. :)
speedtest + doom in DOSBox - as described there
mb it's mighty to play XT era games. it's rather curious
Tertz
Postby feipoa » 2019-2-01 @ 00:06
I'm pretty sure I have some version of DOSBox (.72, I think) installed on my 486's in NT 4.0. Has it become a thing to benchmark games in DOSBox on a 486? Doom 'eh? I'll try to remember to do this when I pull it out next.
EDIT: Wait a minute. Your PPRO 200 gets 2.9 fps in DOOM 1.9? And we want to bench a 486 in DOOM/DOSBOX? You all have reached an all new level. I don't even know if we can call it a level.
User avatar
feipoa
Postby Tertz » 2019-2-03 @ 20:36
feipoa wrote:I'm pretty sure I have some version of DOSBox (.72, I think) installed on my 486's in NT 4.0. Has it become a thing to benchmark games in DOSBox on a 486?
Should be used 0.74 (not 0.74-2 or other)
You may use any OS. But NT may to have higher background services load, than Win9x where it may to work faster. Mb there are LiveCD based on Win9x or the possibility to install Win9x.
Pentium Pro allows up to 2.3 XT level. Fast 486 160 MHz has a chance to give ~1 XT level. With lower performance it would stay acceptable for non-action games, at least. The other testings there are interesting for CPU comparisions.
Tertz
Postby rmay635703 » 2019-2-04 @ 13:52
DonutKing wrote:
Edit2: Now this is interesting, apparently AMD made PGA Socket 3 chips well into the 90's!!
Think of the overclocking potential
http://www.cpu-world.com/CPUs/80486/MANUF-AMD.html
If I'm not mistaken the Am486DX2-66V16BGC about 4th up from the bottom has a datecode of 1998... I'm guessing for embedded/industrial applications because I don't know why you'd buy a 486 desktop in 1998 :P
Walland had complete AST DX2 Win95 systems for $500 very late, 97?
I recall a few AMD 5x86’s coming OEM with Windows 98
Odd times back then you could buy a new 486 or a new 900mhz system
Though I suppose my folks bought a cheap Tandy 1000rlx new in 1993 without a hard drive and Pentiums were on their way at that point.
Now days the difference from high end and low end is more marked by videocards than cpu
rmay635703
Postby Intel486dx33 » 2019-2-11 @ 15:24
I am running win95c and it works okay. I am also using an 8gb. CF card. Worked fine with conventional hard-drive too.
I tried win98 too but it would barely run on this cpu.
Minimum requirements for Win98 is a Pentium class cpu.
User avatar
Intel486dx33
Postby feipoa » 2019-2-11 @ 22:29
Some number of years back, I compared benchmarks on a 486 when using Win98SE vs. Win95c and there was no discernible difference in the results.
User avatar
feipoa
Postby Ponjiayulady » 2019-2-20 @ 18:12
I got a Pentium overdrive 83mhz cpu recently
Spec:
POD83 clocked at 83mhz
16mb ram
3Gb hard disk
256kb cache
Mobo - Msi 4144 socket3 ( SIS Chipset )
Windows 95 osr2.5
Results:
Ponjiayulady
Postby Ponjiayulady » 2019-2-20 @ 18:30
More results on Pentium overdrive 83mhz
Speedtst:484043
Dhrystones / second :24096
Other tests:
Ponjiayulady
Postby Intel486dx33 » 2019-3-22 @ 14:29
Tertz wrote:Intel486dx33
Here is the DOOM game test results. What do you think is this score good ?
DOOM - 2134 gametics and 1894 realtics.
Speedsys - 561728 , 208.3x
User avatar
Intel486dx33
Previous
Who is online
Users browsing this forum: aaronkatrini, alvaro84, Google [Bot], kixs, MrSmiley381, obaltus, vga256, Vynix and 11 guests
