The Ultimate 486 Benchmark Comparison
Reply 201 of 210, by stalk3r
Nemo1985 wrote on 2020-02-11, 21:11:
Yes they should be the very same, but if you are willing test them both, even cpuchk could show if there is any difference.
I ran some quick test on both Ti 486 DX2-80 and It's ST 486DX2-80 and compared them against a Intel DX2-66. It's a VLB system with BIOS timings left on default. Both DX2-80s gave the same results.
Reply 202 of 210, by CoffeeOne
Hello,
I am ran some dos benchmarks and cache check utilities on my Compaq Prosignia Server.
It has a Pentium Overdrive 83MHz, 112MB RAM and a Compaq EISA Qvision 1024/E graphics card:
Let's start with the xvesa102 tool, it also measures VRAM speed:
╔══ÁVESA video mode speed resultã════════════════════════════════════════════════════════╗
║ VESA Version: 1.2 ║
║ OEM name: Compaq QVision 1024 (1 Mbyte) ║
║ Capabilities: 00000001 ║
║ Video memory: 1,024 Kbytes - Detected: 1,024 Kbytes ║
║ Video mode: 0101 - (640x480x8) ║
║ Read 8 bit: ████ 1,170 Kb/s ║
║ Read 16 bit: ████████ 2,340 Kb/s ║
║ Read 32 bit: █████████████████ 4,690 Kb/s ║
║ Read 64 bit: ████████████████ 4,570 Kb/s ║
║ Read 80 bit: ████████ 2,390 Kb/s ║
║ Write 8 bit: █████████████ 3,720 Kb/s ║
║ Write 16 bit: ███████████████████████████ 7,440 Kb/s ║
║ Write 32 bit: ███████████████████████████████████████████████████████ 14,800 Kb/s ║
║ Write 64 bit: ███████████████████████████████████████████████████████ 14,800 Kb/s ║
║ Write 80 bit: ██████████████████████████████████████████████ 12,400 Kb/s ║
╚══Á[ESC]=Close window,[F2]=Save result to TXT fileã═════════════════════════════════════╝
OK, so it's a already proven, that this graphics card is awesome under DOS 😀
Text output from the "Speedtst" tool:
The Speed Test, version 1.14 1996-Apr-11
ARA Copyright (C) 1994,95,96 (2:5020/234@FidoNet)
Agababyan Robert Assotiation
Used TMi0SDGL(tm) Version 1.18
Use SPEEDTST /? for help
þ Detected Long mode
þ Detected Pentium iP5 CPU (Intel Pentium-83MHz with Internal FPU)
Pentium iP54-75(1.5-120), Intel Triton 801762
Pentium iP54-75(1.5-120), VIA 82C875/876 801762
Pentium iP54-75(2-120), Intel Triton 794760
Pentium iP54-75(2-120), SiS 501/503 794760
Cx5x86-M1sc-100(3-150,Opt) 755187
Cx5x86-M1sc-100(3-150,Opt) 742857
Pentium iP5-100, ALR Revolution 666667
Pentium iP54-75(100), Intel Triton 664234
Cx5x86-M1sc-100(2-120,Opt) 602649
Cx5x86-M1sc-100(3-120,Opt) 602649
Pentium iP54-75(90), Intel Triton, ASUSTeK P54-TP4 600660
Am5x86-133-X5-P75(4-160), SiS 471, BTC 4SLD5.1 556575
Cx5x86-M1sc-120, ASUS PVI-486SP3 rev. 1.21 529070
Am5x86-133-X5-P75(3-150), SiS 471, BTC 4SLD5.1 521490
Cx5x86-M1sc-100(Opt) 504155
û This computer 495913 parrots, 183.9 XT
Am5x86-133-X5-P75 463104
Am5x86-133-X5-P75, SiS 471, BTC 4SLD5.1 461929
Nx586-90, NxVL System Logic, Alaris 449383
Pentium iP5-60(66), PCI58PL 446078
Pentium iP5-60(66), SiS 501/502/503, ASUS P5-SP 443902
i80486DX2-66(4-100), PC Chips 18 438554
.... skipped.
And then:
Output from the cachemess tool from the german computer magazin ct:
1.02 MiB
Dhrystone1:
908.33 KiB
Dhrystone2:
1.01 MiB
Then switching to "philcomputerlabs" dos benchmarks:
Superscape benchmark 1.0c ("for faster PCs"):
590.03 KiB
Then "chrisbenchmark". Unfortunately that does not work in 640x480 on that PC (vesa driver was loaded though), so just VGA:
687.74 KiB
Reply 203 of 210, by CoffeeOne
More benchmarks of the same computer:
PC Player Benchmark score 7.2, that ran in 640x480 with the compaq vesa driver.
778.46 KiB
Doom:
918.6 KiB
and score:
701.4 KiB
then quake also chosen 640x480.
Not sure if it was really 640x480, looks a bit strange, but I never played quake honestly spoken.
1.04 MiB
Quake Score:
1.02 MiB
16.5 FPS is OK for an EISA computer, isn't it?
Reply 204 of 210, by CoffeeOne
More Screenshots:
System Information 8.0
715.6 KiB
Landmark 6.0
912.78 KiB
speedsys 478:
1.23 MiB
and
1.06 MiB
and finally cachechk
1.04 MiB
Reply 205 of 210, by CoffeeOne
The same benchmarks (some slight differences):
from my second 486 computer: mainboard micronics asic eisa 256kb cache wt, Am5x86-133 with adapter in wt-mode, 64MB RAM fast page mode 30 pin, graphics ATI ultra pro eisa 2MB VRAM, adaptec 2742W, IBM 9GB wide harddisks.
I post everything with pictures, sorry that they are bit blurry, but I think still more entertaining than ascii text 😀
So the first 5 pictures:
1)
First the "cachemess" utility ctcm from Heise Ct. The values are not bad for a mainboard from 1992, most important: The board's L2 cache covers the maximum possible RAM = 64MB:
997.26 KiB
2)
xvesa102 tool: VRAM speed for Video mode: 0101 - (640x480x8)
Wow, so the high end EISA ATI card seems to be really slower than the Compaq Qvision 1024/E under dos, interesting
857.98 KiB
3)
speedtst
1.08 MiB
4)
dhrystone1:
892.96 KiB
5)
dhrystone2:
1022.11 KiB
Reply 206 of 210, by CoffeeOne
The next 5 pictures:
1)
Superscape benchmark (for fast PCs) 😁
721.22 KiB
2)
Chris' benchmark, on this computer it worked in 640x480 8 bit, so not comparable with the number from the Compaq Prosiginia Server
618.16 KiB
685.35 KiB
3)
PC Player Benchmark 640x480
827.51 KiB
4)
Doom 640x480, result only:
658.64 KiB
Reply 207 of 210, by CoffeeOne
Quake 640x480: 10.9FPS, not too bad for a 486cpu in my opinion
1.03 MiB
2)
SI 8.0
747.71 KiB
3)
Landmark 6.0
995.17 KiB
4)
cachechk
So memory access is a bit slower than the Compaq Prosignia Server, also confirmed by this tool.
1.06 MiB
5)
sysinfo 478
I am little bit irritated that the harddisk benchmark gave a slower score for this machine (Wide SCSI hdd has slower write speed than the narrow SCSI?), but I won't investigate further.
1.19 MiB
Reply 209 of 210, by CoffeeOne
More benchmarks for the last 2 machines:
Winstone 95 running Windows 98SE:
Compaq Prosignia Server:
84.83 KiB
Custom PC with mainboard Micronics ASIC EISA:
84 KiB
Reply 210 of 210, by S2 Sedan
I have an M919 with 256k cache Stick
I have try 4x40MHz and 3x50MHz both running without problems at 3.3V
have try multiple benches but for me the doom ist most important, and DX4-150 gets 1825. as DX5-160 i only get 2072 (less iss better)
Would be intresting to know if ther is a FSB60 option on this Bord. I heard about it but dont find closer details.
    197.77 KiB
    204.03 KiB
