SavantStrike wrote:Nice! […]
Tetrium wrote:Oh man, I've just done some browsing about the Nehemiah and closed a window that explained how the Nehemiah multi could be unloc […]
Oh man, I've just done some browsing about the Nehemiah and closed a window that explained how the Nehemiah multi could be unlocked (max multi was 12x).
I'll go look it up again...
Edit:1 search, 1st result, thank god, 🤣
http://ixbtlabs.com/articles2/roundupmobo/via … 3-nehemiah.html
Iirc it was the earlier ones that were unlocked. I'm in the middle of testing all my s370 boards and want to go and test the C3 CPU's I have laying around.
If I'm done, I'll report back here 😉
Nice!
I hope it turns out well. If you've got non ezra C3 chips, make sure to hold on to them too. I can't find any. Apparently no one wanted the C3 chips when they were out  😁.
I love the idea of a C3 for vintage gaming though for some reason. It's a unique set up.
As for the multiplier unlocks, I wonder if that goes in the other direction. Access to multipliers of 1x, 1.5x, and 2x would be ideal.
I'm done with the testing! 😁
And actually, of the 6 chips I own, none appear to be Ezra.
The chips are:
VIA Cyrix III 550 (5.5x100) 2.0v (Samuel?)
VIA C3 700 (7x100) 2.0v (Samuel?)
VIA C3 866 (Nehemiah?)
VIA C3 1000 (Probably Nehemiah)
VIA C3 1200 (Can't be anything but a Nehemiah)
I tested using an ASUS CUSL2 with one of the newer BIOS versions (I think it was 1009?).
First I set everything to it's lowest (66Mhz "FSB" and 100Mhz Memory Bus (The 815 started having it's busses separated)), then tested with a known good P3 733 with a copper cooler without thermal paste (I'm low on paper towels ahem).
Then I tried the Cyrix III, but it gave no screen and then the "overheating" beepcode, no good.
Perhaps the board didn't support PPGA Celerons (which also require 2.0v), so I continued only with the lower voltage >866 chips as I'd rather not fry the board. Edit2: Reading the online manual it appears the CUSL2 supports PPGA Celerons just fine, so will try out the 700Mhz C3 when I continue testing again. Hopefully it's multiplier can be chanced
The other 4 chips posted alright, but were recognized as a Pentium II, 🤣
Alas, those 4 had their multi's locked, but according to the article I found earlier today they should be unlockable.
Another encouraging thing was that the 1.2Ghz part had, according to the BIOS, a 16x multi, even though it was running at it's normal 9x multi, and that kinda affirms the story written in that article.
I also got my power reader thingy and brought it to my attic, I'll test later how the C3's power consumption is 😉
Edit: I forgot to mention, even though the BIOS didn't recognize the C3's correctly, the board did supply the correct voltage!
