First post, by ibm5150pc
I am aware of all the negatives of OEM Name brand systems have today, that they all use the cheapest lowest grade parts out there and non standard parts and so on, and how it's ten times better to build your own ect.
Dose that also apply to the systems from OEM's such as Gateway, HP, DELL Compaq system's from 1994 - 2001. I have a number systems to pick from, mainly two HP's and two Gateway's. HP is 300Mhz 2nd HP is a 700Mhz 1st Gateway is a 433Mhz and the 2nd Gateway is 633Mhz all Celerons.
HP's are Pavilion's and Gateways are 433C and GP all small towers non standard power supplys.
I am looking at a Windows 98 System to play Quake 1 DOOM NFS Ect. All the system's have integrated graphics and sound, Do I have to add in a PCI graphics card to say run Quake 1 at 800X600 or 1024X768 smoothly or any of those games above?
So who is the better OEM, HP or Gateway? I don't want a system to fail or fall apart on me!
