swaaye wrote:Oh yeah that's true. You have to be on DVI though I've noticed or the options go away for some reason. This is annoying with TVs cuz TVs look better on VGA than HDMI usually. There's less ugly processing used.
Ahh I se...
Never tested it with VGA 😁
Regarding TVs. HDMI "can" work very well IF your TV has an option to configure the HDMI input for a PC.
Often TVs have one out of three HDMI ports "PC aware" or there is an option in the menu.
I take it you refer to the issue of overscan? Getting black bars around or the image being too large?
This can also be compensated for in the driver, but ideally you confiure the HDMI to be "PC aware" if it has that option. I know Panasonic most certainly do.
If you play on a TV, make sure the ouput is 1280 x 720 or 1920 x 1080. But yea, I can see how a 800 x 600 signal would look weird via HDMI because it's not a digital TV resolution.
