Reply 60 of 62, by GuillermoXT
- Member
I did ask that question on another forum already but did someone managed to get a cf (Master) and a CDrom drive (slave) working together using only a (non-pnp) soundcard's IDE port?
Currently the cf only seems to work combined with the Xtide Bios attached on a network card.
When I connect a hdd as slave instead of the CD Drive both are successfully detected.
Even when i boot with floppy (Xtide pulled out)
with drivers and connect only the CDrom it won't work.
Before i used unisound on a pnp card and it worked fine.
EDIT: CDRom works now with and without xtide BIOS booted by Floppy but when i combine it with a cf or hdd vide-cdd.sys does not detect the CDRom drive.
My Retrosystems:
K6-2 400 running Win98SE
P1-133 with Win3.11
Tandon 286-8MHZ Running DOS 5.0 on XT-IDE Card
