First post, by iulianv
- Member
A few days ago I received an IBM ThinkPad 600e laptop - unfortunately, the output wire and connector of its original charger are unusable until I find someone skilled enough to repair them.
In the meantime I found an "Acer by Lite-On" charger, with the same connectors as the original IBM; the only issue is that, while the IBM is labelled "16V/3.36A", this one outputs 19V/3.16A.
Is it a big deal if I use the Lite-On? Or can the laptop's internal voltage regulator(s) deal with the ~19% increase in voltage...
