First post, by dirkmirk
I have a socket 3 mainboard based on the sis 496/497 that will no longer work with 3v cpus.
I bought the board and it initially worked with a cyrix 586-100 and AMD P75-133, for some reason it stopped working with those cpus but works everytime with a 486 DX33 and DX2-50 at stock and overclocked speeds.
I've tried running the default jumpers and setting for 4 & 5V cpu and they still wont work, I also tried a amd 486DX4-120 and it wont work, both the AMD chips work 100% as ive tested them on other 486 mainboards and I think its safe to assume the cyrix cpu is still fine.
Has anyone ever come across this kind of issue? I might have to live with the board running a lower spec cpu but it was'nt the intended purpose for this machine and 486 boards with 5x86 support are rare/expensive.
Any tips?
