I dug this old beast out of storage to see if it still worked and everything in the self test passed except for the clock battery (not unexpected), the floppy drive test passed then when it tried to boot from the hard drive the hard drive light flashed but then it gave a hard drive boot error. What should I be looking at as the cause of the hard drive not to boot?
The clock battery shouldn't affect the hard drive, though, since the drive type is actually set by jumpers (assuming it's the original drive controller in there).
Speaking of which, since the info is a bit difficult to find, here's the various options:
61 B. 51MB - CDC Wren II 94205 ..OO..CO OO..CO.. ..OO..CO OO..CO.. 62 C. 67MB - CDC Wren II ..CC..OO CC..OO.. ..CC..OO CC..OO.. 63 D. 68MB - Micropolis 1325, 64 Miniscribe 6085, 65 Seagate 4085 ..OC..OO OC..OO.. ..OC..OO OC..OO.. 66 E. 40MB - Seagate ST251 ..CO..OO CO..OO.. ..CO..OO CO..OO.. 67 F. Drive #0 ONLY, no #1 ........ OO..OO.. ........ OO..OO.. 68 C = CLOSED = ON C = JUMPER ON 69 O = OPEN = OFF O = JUMPER OFF
I ordered a bunch of 2032 coin cell batteries for other projects. I hope that's the same type this machine uses. I'll have to wait a few days for them to arrive then try again.
Old Thrashbarg Yup your rigth that really old hardset motherboard with dip switchs
By the way sliderider if it has 2 5.25 floppy drive then it didn't come with harddrive.
That will not do any good all thoses old 8086, 80286, 80386, 80486, and belive even 80586 didn't come with coin cell batteries and there a few that did but not the AT&T PC6300.
Here a list of image on ever type CMOS Battery and Clock & Battery Module http://simondirect.com/blog/?p=1613
No coin cells on this thing. It has a rechargeable barrel battery similar to the type normally found on 386/486 boards, though there's also unpopulated space on the board for a different, much larger battery, I'd guess probably a 14650 size or something...
Unless the battery is leaking, though, there's not much reason to replace it. It only holds settings for the clock and calendar, nothing more, and the calendar only goes up to 1991 anyway.
Mine had this battery on the board. Its a lithium thionyl chloride battery, non rechargable.
But not leaky either after 35 years. I dont see a diode to prevent charging a non rechargable, perhaps the connection points are different.
