Tillamook 266MHz and working L2 cache?
Reply 141 of 505, by feipoa
LeFlash wrote:
Anonymous Coward wrote:
feipoa wrote:
Nice! Any chance this mod will make the CPU/cache work in a 430TX board?
I'm waiting for the answer to this one too.
Give me a board and i'll report 😉
All I can do is add it to my list, which is approaching infinity. So many other things have a higher priority though. I'm sure someone else will this hardware combination will get to it before me.
Reply 142 of 505, by LeFlash
Right now i can say that the VIA MVP3 and the 430HX work. So the TX should, in theory, work too.
But it depends on the BIOS as well. I've got 2 industrial PC cards with the 430HX, there the CPU doesn't even post.
Reply 144 of 505, by Anonymous Coward
LeFlash wrote:
Quick follow up: GA-586HX (430HX) also working!
With L2 cache on? That would be a first for a 430 chipset.
Reply 146 of 505, by LeFlash
Yes, of course!
Speedsys graph follows, have to mod the board before doing extensive tests because its lowest voltage is way to high for the CPU.
Reply 148 of 505, by LeFlash
Yep. That's what i was trying to tell everyone. I checked with an unmodded vs. modded CPU and it solves the problem of L2 cache, as long as the mobo bios detects the CPU (which nearly every bios should do)
Reply 151 of 505, by amadeus777999
Excellent news.
Reply 153 of 505, by amadeus777999
feipoa wrote:
amadeus, are you able to test this mod in a 430FX, 430VX, or 430TX board?
I do not know which chipsets I have, there are 5 S(S)7 boards in the storage - at least one bearing an SiS5591 chipset. I also have to buy the Tillamooks since I didn't follow through originally due to not being sure about optimal performance.
Should I be able to gather some data, then YES.
Reply 154 of 505, by LeFlash
Ok guys, another one.
This time: 112MHz x 3.5 => 392MHz
Quake Timedemo over 80fps, even with 640x480 over 20fps!
Board is a FIC VA503+ this time - only board i had on hand with >100MHz
248.63 KiB
245.95 KiB
228.54 KiB
Reply 158 of 505, by Nemo1985
LeFlash wrote:
Ok guys, another one. This time: 112MHz x 3.5 => 392MHz […]
Is this a 266mhz oc to 392, right?
Reply 159 of 505, by feipoa
I wonder if the chip is long term stable at 350 MHz. That would make for a desirable setup.
EDIT: I predict a 430TX board, if it will work with this chip, will score about 20.x FPS in software Quake at 640x480 when run at 83.3x3.5, or 292 MHz.
