Reply 20 of 22, by omarsis
wrote:I'd say so. I have a couple of dual EGA/VGA cards myself. VGA is 15 pin and EGA/CGA/MDA/Hercules are 9 pin. You'll need to set t […]
You'll need to set the DIP switches for the correct output mode, maybe stason.org will have the settings.EDIT: keropi's got a point, 5 crystals on that card is unusual. But without seeing a circuit diagram who knows what they do?
My ATI Wonder EGA card has two crystals, I've seen some other EGA cards with three. Perhaps the extra crystals are there for the different sync rates of VGA? or they could just be for the card's video RAM or something else.
Does anyone have the dip switches and the jumper settings for this dual VGA/EGA card? I have one identical card and I can only get it to display monochrome on a LCD monitor!
