The All-amazing super-de-douper SuperPi thread!
Re: The All-amazing super-de-douper SuperPi thread!
Postby agent_x007 » 2016-11-21 @ 19:46
Going "warp speed" on Air cooling :D
OC'ing old stuff is so much FUN :)
User avatar
agent_x007
Postby Imperious » 2016-11-24 @ 07:47
Most likely unstable at this speed, at least for games. Dropped it back to 4017mhz afterwards
Abit KT7-RAID,Athlon XP-M Barton@450-2400,512mb Sdram,Quadro FX3000,Voodoo1,Vortex 2 and SB16 CT2740,Win98
Lucky Star LS-486e,Intel 486dx2-66,64mb EDO,S3 Trio64V+,AWE64 value,Win95
Imperious
Postby sprcorreia » 2017-2-17 @ 04:54
One more result to the "table".
Dual P3 450MHz - 04m 23.797s
EDIT: After some RAM tweaks, 04m 20.734s
ASUS P2B with P3 1100 for sale.
http://www.amibay.com/showthread.php?95680-Asus-P2B-Rev-1-10-Intel-P3-1-1GHz-with-Asus-adapter-and-Coolermaster-cooler
Lots of other stuff too. PM me for more details.
User avatar
sprcorreia
Postby Skyscraper » 2017-3-30 @ 16:17
Abit AN7, Athlon XP-M 2800+ @ 11x228 (2500MHz), 1x1GB DDR @228 2.5-3-3-11 CPC
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 780 Ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Skyscraper
Postby lazibayer » 2017-9-01 @ 00:16
lazibayer wrote:Still the same platform:
CPU: K6-3+450 ACZ
Mobo: P5A-B
RAM: 256MB PC133 2-2-2
OS: XP SP3
But this time I turned off some services and the fancy interface.
112x5.5:
The attachment p5a_112_55_superpi_0.jpg is no longer available
124x5, no L3:
The attachment p5a_124_5_noL3_superpi_0.jpg is no longer available
112x5.5, no L3:
The attachment p5a_112_55_noL3_superpi_0.jpg is no longer available
Same hardware platform, OC to 133x4.5, no L3:
User avatar
lazibayer
Postby noshutdown » 2017-11-24 @ 02:01
amd386dx-40
cyrix fastmath 83d87-40
the infamous macronics 83c306/305 chipset, which has 8kb integrated cache but no onboard cache
16mb dram
time: 5h 56m 15s
this is very disappointing because my original expectation was 4-4.5 hours. guess the only way to improve is to find a board with 128kb cache, it may get under 5:30 but less than 5 hours is unlikely.
noshutdown
Postby Imperious » 2017-12-03 @ 13:42
Celeron 2.6 Northwood @ 3357mhz
Imperious
Postby Imperious » 2017-12-20 @ 13:29
Celeron D does quite a bit better than Celeron Northwood
Imperious
Postby agent_x007 » 2018-3-18 @ 18:03
X3370 + 240mm AIO w/Delta fans :
A bit slower than QX9770 @ 4,5GHz from before... however, it's with higher FSB and not deadly Vcore (stable for high load 3D benching as well).
User avatar
agent_x007
Postby bakemono » 2018-3-18 @ 21:11
already have collected these results, might as well post...
Athlon II X2 260 (3.2GHz, DDR2-800 CL5) - 25s
Athlon X2 7850 (2.8GHz, DDR2-800 CL5) - 28s
Core2 SU9600 (1.6GHz, 1.8GHz turbo, DDR2-667) - 34s
Athlon X2 4850e (2.5GHz, DDR2-800 CL5) - 36s
Turion X2 1.6GHz (DDR2-667) - 57s
Athlon XP 2800+ (2083MHz, KT333, DDR-333 CL3) - 1m
Athlon XP 2500+ (1833MHz, KT333, DDR-333 CL2) - 1m1s
Sempron 2300+ (1583MHz, KT333, DDR-333 CL2) - 1m15s
Pentium M 1MB 1.0GHz (i855pm, DDR-266) - 1m25s
Pentium M 2MB 1.2GHz (i855pm, DDR-266) - 1m4s
Pentium M 2MB 1.2GHz (i915gm, DDR2-400) - 1m1s
Pentium M 1MB 1.7GHz (i855pm, DDR-333) - 56s
Pentium M 2MB 1.6GHz (i855pm, DDR-333) - 53s
Pentium 3 933MHz (PC-133) - 2m17s
Pentium 3M 800 (i830gm, PC-133 CL2) - 2m35s
Pentium 3M 1333MHz (i830gm, PC-133 CL3) - 2m20s
Pentium 3M 1333MHz (i830gm, PC-133 CL2) - 2m06s
Pentium 3M 1333MHz (i830gm, PC-133 CL2) - 1m57s (screen mode at 800x600x16 instead of 1024x768x32)
Pentium 3 600e (PC-100) - 3m21s
Pentium MMX 166 (256KB L2) - 15m2s
bakemono
Postby Skyscraper » 2018-6-21 @ 22:37
Here is an Intel i7 3770K running on an Asus Maximus IV Extreme P67 motherboard. The OS used is Windows 10 with USB WLan and other bloat running in the background.
i7 3770K @4.8: 7.625s
Skyscraper
Previous
Who is online
Users browsing this forum: Illy76_it, linkdex [Bot], stege and 12 guests
