Reply 340 of 402, by rmay635703
- Oldbie
vmr_ wrote on 2023-11-30, 15:01:Same goes for MII 350 - seen so few of these - guess production was very limited.
The production MII-pr350 required a 90mhz FSB and thus only worked with one motherboard .
They (IBM) designed all MII/6x86mx above pr300 and quickly moved to 83mhz fsb (pr333) once nobody standardized to that 90mhz fsb and Cyrix eventually went to 95/100mhz FSB for pr366+ on chips labled with their namesake, strangely IBM was more heavily involved in Cyrix after the agreement/ partnership dissolved then they were before
As for 8087, the primary difference between the golden original and later 287+ examples was that the original 8087 had an mmu of sorts and could fetch its own data, this made it somewhat faster clock for clock than a normal 287 or 387
