First post, by Robin4
- l33t
Today i received my 80286/10 suntac motherboard. I hadnt tried it out, untill now.. Hoped that it would right out of the box. But NO it didnt..
So i checked the jumper settings, and something wasnt right.. When i changed the settings, the board gave me the screen i was hoping for..
Then i couldnt use my keyboard.. only ESC did work on mem test.
It gave me
A keyboard error
Cmos system failure
Cmos system options not set
Floppy drive error..
So it was a little hassle to find out what to problem was..
When the memory got counts, i could press ESC to go further, but for the rest no keyboard input.. I got already lost my patience, and got already all setting done right. So i thought lets try to get out the keyboard bios IC..
So i did, and blew the socket clean, and put the IC back..
Yes keyboard got working, and i could enter the bios..
But i only got a real big problem. Its very hard to get those expansion cards got installed.. Then wont get in.. Is there a solution for it???
Is it maybe a good idea to lubricate the slots with some off contact spray special for Printed circuit board?
Further, this board got 2MB of memory installed. And regonize it as full memory.. like a 80386 do..
Iam also can it set as 640KB + 1408kb
It can use 4MB of memory.. Also this board have a place for a coin bios battery.
Iam also have bought a AMD 80286 16 mhz processor for it, it has now a 10mhz installed.
