Reply 40 of 41, by konc
- l33t
wrote:Inside there are two isolation transformers with 1:1 turn ratio simply to galvanically isolate the interconnected equipment. The […]
The AC sound transferred magnetically through the transformer... like magic no wires.
The source of the hum/noise these isolation transformers fix is usually ground loops noises and it is not the kind of noise this thread is all about.
The cheap ones from ebay cut the bass below 50Hz and alter the phase response, I have a few myself and do not recommend for any serious audio application where sound quality matters.
Further reading: http://www.epanorama.net/newepa/2010/08/12/au … n-transformers/
Perfect answer, guys this is exactly what's happening. Galvanic isolation electrically separates devices and resolve ground loop, the (very) cheap ones are nothing but filters.
