I'm building a Socket 7 PC
Reply 41 of 45, by feipoa
If you are comparing the Quake3 benchmark of a Cyrix MII at 266 MHz to a Pentium 166MMX, you should really be consistant with which graphics card you are using.
From my work on the Ultimate 686 Benchmark Comparison (in progress), I noticed that a Cyrix MII @ 233 Mhz yields about the same results of a Pentium 166MMX in Quake 2.
Pentium 166MMX
Quake2 - OpenGL - 17.9 fps
Quake2 - Software - 10.1 fps
Cyrix MII 233 MHz
Quake2 - OpenGL - 17.7 fps
Quake2 - Software - 9.9 fps
For added comparison,
Cyrix MII 292 MHz (83.3 x 3.5)
Quake2 - OpenGL - 22.6 fps
Quake2 - Software - 12.5 fps
which is a little bit faster than a Pentium 233MMX,
Pentium 233MMX
Quake2 - OpenGL - 22.7 fps
Quake2 - Software - 11.9 fps
If Quake2 is a good approximation for most games of the time (1998-1999), then the fastest, and last, Cyrix CPU (MII-433GP) was about as good as a Pentium 233MMX. For office/internet applications, the Cyrix MII-433GP would be a much better choice than a P233.
The 292 MHz Cyrix MII was tested using an 83 MHz FSB, so perhaps running the MII at 100 MHz x 3.0 would equate to about a Pentium 262MMX in Quake2?
For your interest,
Pentium 262MMX
Quake2 - OpenGL - 25.1 fps
Quake2 - Software - 13.7 fps
Reply 42 of 45, by Chewhacca
SquallStrife wrote:
mwdmeyer wrote:
The hardest part was finding non-80pin IDE cables without a blanking pin.
I gave up on that.
Now I just use new cables, with small drill bit (~1mm) and a steady hand!
If you aren't shy about spending money, you can just buy the stuff from an electronics store and terminate your own cables.
Reply 44 of 45, by mwdmeyer
Alright. Got a benchmark working in quake 2 demo.
Software 640x480 9.6fps
OpenGL 1024x768 32fps
This was with the demo benchmark so not sure if the results are comparable.
Reply 45 of 45, by mwdmeyer
FYI I am very happy with the GeForce MX4000 PCI. No fan, doesn't get hot, seems to run well and it only cost $12 on eBay. I should have purchased another one!
