Reply 60 of 64, by swaaye
wrote:While it is true that V2SLI is limited on a K6 platform, I do not agree that Quake2 isn't screaming along. These benchmarks are […]
While it is true that V2SLI is limited on a K6 platform, I do not agree that Quake2 isn't screaming along. These benchmarks are from my 66mhz FSB K6 system. A proper SS7 board will get even better results:
GLQuake (demo1):
AMD K6-2 400mhz - 1024x768 SLI - 40.8 fps
AMD K6-3 400mhz - 1024x768 SLI - 57.6 fpsQuake 2 (demo1):
AMD K6-2 400mhz - 1024x768 SLI - 57.4 FPS /w 3DNow driver
AMD K6-3 400mhz - 1024x768 SLI - 67.8 FPS /w 3DNow driver
Yeah the K6 has enough grunt to get the job done with Quake 2. If you want to play Quake 3 or UT, then even a K6-3+ at 600 MHz is inadequate. The Voodoo2 SLI setup has no problem with those games but the K6 chokes badly.
