First post, by noshutdown
the purpose is to find how much impact the mainboards have on performance.
the bench should cover most chipsets: intel, umc, ali, via, sis, opti, winbond, and probably others, and see how their performance vary when using same cpu, ram and video configurations.
i suggest to use intel dx4-100wb on all boards, which shall be enough to see some difference between boards, while not having compatibility issues that amd5x86 and cyrix5x86 do.
