First post, by Great Hierophant
- l33t
My brother in law used to be big into PC gaming, and knowing my fascination with vintage hardware, he bestowed on me the only thing he kept from his last desktop, a Voodoo 3 3000 PCI with 16MB SGRAM (identified thanks to Falconfly). Unfortunately, he has been using laptops ever since, so the system got junked but the card survived.
So I have this graphics card, but I don't have any systems with PCI slots to put it in. I am thinking of building a cutting-edge 1999 system, using parts available from that year or earlier, wherever feasible. So I would do the following with a Windows 98SE build :
Pentium III 600EB Slot 1
ASUS P3B-F or Abit BX6 2.0
256MB PC133 SDRAM CL2
IN WIN S-Series S508T w/350W ATX Power Supply
Voodoo 3 3000 PCI
Aureal Vortex 2 Sound Card (Diamond Monster Sound 3D MX300 most likely)
3Com 3C905B-TX Fast Etherlink XL
Microsoft PS/2 Intellimouse
IBM Model M Keyboard
Epson SD-880 Combo Floppy
Creative PC-DVD DXR2 DVD-ROM drive w/decoder
Sound Blaster 16 (model TBD)
Microsoft Sidewinder 3D Pro
30GB Hard Drive (probably Western Digital)
Since I have a PCI Voodoo, I can run the FSB without the instability caused by an 89MHz AGP bus. Back in the day my Geforce 256 ran fine on the AGP bus, but a Voodoo card?
The case is one area in which I have to compromise, I don't want someone's yucky old case. Still, this case does not have a hard drive cage that descends to the bottom (blocking off full-length ISA cards) and its ATX power supply is v1.3, so it will still support -5v.
The hard drive is another. 30GB was not likely to be had in a single drive in 1999, but the high end drives were close to or around that spec. I don't want to buy an old, failing hard drive when these are cheap. Above 32GB, FAT32 cluster sizes are an enormous 32KB. If I did want to go the higher capacity route, I would use a Promise Ultra 133 TX2 PCI controller, which can support 48-bit LBA and has a Windows 98 driver.
For audio output, I would use Klipsch v2-400, nice speakers then as they are now, if I could find a set cheap. For a monitor, I have a KDS VS-7p 17" CRT VGA monitor. It can do up to 1024x768 @ 75Hz and 1280x1024 @ 60Hz. Were money no object I would love a Sony GDM-F500 21" Trintron tube.
Back in 1999, if money were truly no object, I would probably have investigated the world of SCSI (Adaptec AHA-2940U2W Ultra 2 Wide SCSI) and the appropriate IBM Deskstar drives.
Also, back in 1999, the fastest Pentium III I could have bought (in theory) would be the 800EB, but that would be a bit too fast for my purposes. The alternative would be an Athlon at 750MHz, but I have never been comfortable with Slot A stuff. I could stuff the machine with 512MB of SDRAM, but that would be overkill as well. [/list]
